Civic runs rough for first 10-30 seconds...then it runs normal.
Hi, i have a 1998 civic ex and I've been having this problem for a couple of months now.
Sometimes when i start it, it runs rough for 10-30 seconds (rpm's fluctuate a little bit) then it runs normal. Usually it happens in the morning when i go to school, but it happened a few times later when i left school too.
First I thought it might just be some moisture in the throttle body but then yesterday the engine light turned on. I went to autozone and they pulled P0301 and P1399 out, which is Cylinder 1 misfire and Random cylinder misfire, respectively.
Oh and the car had a complete tune about 1 year ago by previous owner.
I am also slowly loosing coolant but i don't know where/how... if that hepls
I've found one thread on here that had the same exact issue, but the guy never said if he fixed it or not.
thanks
thanks
Re: Civic runs rough for first 10-30 seconds...then it runs normal.
Sounds like a bad headgasket. Pull your spark plugs, espesially cylinder 1's, look for signs of coolant on it. You could be leaking coolant into the cylinder causing the misfire.
Ok so i took the spark plugs off and took a couple of pictures. #2, 3 and 4 looked identical to the one on the left and #1 is the one on the right. I had to regap #1 since it looked about 15% wider than the rest. Could that have been my problem?
One more thing, should i test it with an combustion leak tester if it still sounds like its the head gasket?
thanks again
Thanks for reply,
thanks again
thanks again
id say do the chemical test that you set on top of the radiator. it tests for carcinogens (exhaust bubbles) in the coolant. if you fail the chem test u need a headgasket
well the gap couldve been the problem...does it still idle rough after you re gapped it? #1 doesnt look right at all...every plug ive seen thats been used for a while is white on the tip like 2 3 and 4.
OK I've randomly started the car about 4-5 times today and everything seems fine now after I've regaped #1 plug. I'll buy one of those combustion leak tester tomorrow and see what result i get.
Again, thanks a lot
Agreed. Hopefully that fixed your problem for good, i know our cars are pretty sensitive when it comes to plugs. But id do a compression test also just to be safe.
Keep us updated how the tests go
I finally got the combustion leak tester in the mail and tried it and results came negative. I've also did a compression test on all cylinders and the numbers were 190, 185, 190 and 190.
Plus, ever since i regapped that spark plug the car has worked properly, so i think that was the problem.
Well thanks a lot guys, i really appreciated your help.
dragonsblood
Apr 27, 2015 12:28 PM
SSMatey
Apr 13, 2015 06:09 PM
djdefcon
17
Apr 6, 2005 11:52 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
