1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Clunk in the front end.
Old Oct 3, 2011
tanker1975's Avatar
tanker1975 is an unknown quantity at this point
I recently changed the bushings on the upper and lower front end control arms on my 95 DX. I changed them along with my halfshafts, rotors and brakes, after putting everything back together I noticed a "clunk" sound when driving that was not there before. I checked to make sure everything was tightened and I can not duplicate the sound on the lift. It seams to happen when I go over bumps, seamingly random, and when i make turns and braking at the same time. Can anyone please help with this, I don't want to keep driving it if something is on the verge of breaking.
Thanks.
Old Oct 4, 2011
tanker1975's Avatar
Re: Clunk in the front end.
Anyone have any ideas or any help?
Old Nov 6, 2011
youmadeyou's Avatar
youmadeyou is an unknown quantity at this point
CV axles maybe..if its making a clicking sound while turning and going over bumps .. or a long shot but maybe a lower motor mount..
Old Nov 6, 2011
tanker1975's Avatar
I don't have any clicking just the occasional clunk. like a loose bolt in the LCA or something. I have it up right now changing the headers. I will have to look some more. Any other ideas?
Old Nov 6, 2011
lazlong's Avatar
Probably the top mount bushing(s) but, it could be the mount itself (#8). Also, make sure the bolts on top of the strut tower are tight.
Check numbers 7, 10, and 12 as well as 8:
Old Nov 7, 2011
tanker1975's Avatar
I checked all of these bolts and they are all tight. I also looked around the LCA's bushings, which i changed and I don't see any marks or any signs of movement on any of the bolts or nuts. I am really stumped on this. It is only the front end. Here is what I have changed on the front:
  • Both CV Axles
  • Brake pads
  • Brake rotors - slotted & drilled
  • Brake lines - Stainless
  • LCA bushings - both sides to urethane
  • upper ball joint bracket bushings
  • Ball joint boots - all urethane, came with the Energy Suspension kit.
That is all for the suspension. I had to remove the shock/springs when I did the axles but never disassembled them, just took them out as one piece and put them back when I was done.
Other unrelated mods:
  • MSD ignition coil
  • MSD distributor cap
  • MSD wires
  • AEM Cold Air Intake
  • All new ground 8ga wire
  • New alternator
  • New Headers
Any help on this would be greatly appreciated.
Thanks.
Old Nov 7, 2011
lazlong's Avatar
  • Both CV Axles
  • Brake pads
  • MSD ignition coil
  • MSD wires
  • New alternator
  • New Headers
Thanks.
Read post #5. Yes, you have to take the strut assembly apart to inspect. A spring compressor is required.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
BootyDo
Jun 21, 2016 03:45 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
Dorval Andre
15
Jul 1, 2015 09:32 AM
chuffsy
May 15, 2015 12:50 PM
