Clunk in the front end.
I recently changed the bushings on the upper and lower front end control arms on my 95 DX. I changed them along with my halfshafts, rotors and brakes, after putting everything back together I noticed a "clunk" sound when driving that was not there before. I checked to make sure everything was tightened and I can not duplicate the sound on the lift. It seams to happen when I go over bumps, seamingly random, and when i make turns and braking at the same time. Can anyone please help with this, I don't want to keep driving it if something is on the verge of breaking.
Thanks.
Thanks.
Re: Clunk in the front end.
I don't have any clicking just the occasional clunk. like a loose bolt in the LCA or something. I have it up right now changing the headers. I will have to look some more. Any other ideas?
Probably the top mount bushing(s) but, it could be the mount itself (#8). Also, make sure the bolts on top of the strut tower are tight.
Check numbers 7, 10, and 12 as well as 8:
I checked all of these bolts and they are all tight. I also looked around the LCA's bushings, which i changed and I don't see any marks or any signs of movement on any of the bolts or nuts. I am really stumped on this. It is only the front end. Here is what I have changed on the front:
That is all for the suspension. I had to remove the shock/springs when I did the axles but never disassembled them, just took them out as one piece and put them back when I was done.
Other unrelated mods:
Any help on this would be greatly appreciated.
Thanks.
- Both CV Axles
- Brake pads
- Brake rotors - slotted & drilled
- Brake lines - Stainless
- LCA bushings - both sides to urethane
- upper ball joint bracket bushings
- Ball joint boots - all urethane, came with the Energy Suspension kit.
- MSD ignition coil
- MSD distributor cap
- MSD wires
- AEM Cold Air Intake
- All new ground 8ga wire
- New alternator
- New Headers
Thanks.
Thanks.
- Both CV Axles
- Brake pads
- MSD ignition coil
- MSD wires
- New alternator
- New Headers
Thanks.
BootyDo
Jun 21, 2016 03:45 PM
Dorval Andre
15
Jul 1, 2015 09:32 AM
chuffsy
May 15, 2015 12:50 PM
