weird sound with a burnt out head light
Old Jun 26, 2011
toad78's Avatar
toad78 is an unknown quantity at this point
it's a 04 civic dx. when you start up the car it makes funny sound humm/rattle and the drl light flickers with the sound and the passenger side daytime running light is out. but as soon as you turn on the headlights it goes away (the sound) and low beams work both sides but when switch to high beams passenger does not work.I have changed the bulb and it seemed to fix everything but it only lasted for a day or so and then light "burnt" out again. alsoits hard to tell but i think sometimes at night the highbeam will flicker back on once in a while.
SOOOO... if my DRL's are on then I get a funny sound but once I turn my headlights on it goes away. what is the sound?
Old Jun 27, 2011
CraigW's Avatar
Re: weird sound with a burnt out head light
You need to locate the drl module and re-solder some of the connections.
The info is here on the site and I can give other links if you need them.
Old Jun 27, 2011
toad78's Avatar
if you could, that would be great.
thanks T
Old Jun 28, 2011
CraigW's Avatar
http://api.viglink.com/api/click?for...l-problem.html
This is likely the best.
mrohitredd
18
May 14, 2015 07:35 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
cazminn
Nov 9, 2001 11:18 AM
sonsonzai
Nov 4, 2001 12:52 PM
