D17 Turbo
D17 Turbo
Whats up guys...
Currently im rocking a d17... heres the thing, i'd like to hit atleast the 200-300hp mark... I don't know very much about d series motors, but i was wondering if the motor was built if it would be capable of of handling enough boost for that power reliable?
I know i would be better off purchasing a k series, but i am lacking the cash right now, and i understand these can cost quite a bit in the end.
Re: D17 Turbo
just looking around it looks like some of you guys are hitting 400+ with these motors! i was checking out the internals sticky but i didn't see anything in the 1st post about em. What should i look at upgrading in this thing? How much boost would you have to run roughly for 250hp numbers?
EDIT: Just realized the posts go the other way around :P
Re: D17 Turbo
I'm rocking an LX too man, any experience with coilovers? i'm kind of on the hunt for some but don't know what to get, i'd like to spend like $600
Re: D17 Turbo
the order of the posts have been asked a coupla' times:
https://www.civicforums.com/forums/1...backwards.html
https://www.civicforums.com/forums/1...-not-last.html
Turbos, i will refrain, i just know the theory behind, never did have them on my hands and not interested on them.
Re: D17 Turbo
i made 282 on bone stock motor...well it had arp studs cometic head gasket and a crower stage 3 cam...i had a bad boost leak in the video when i was at the dyno but i got 282hp at 15psi.....it depends on what turbo you are looking to get and how good the tune is but if you get a decent size then prob 10psi will get you are 200-250....if you want 300+ then build the motor.....i now have a bulit motor b/c i wwas at 25psi and the rod finally decided to show it self to me.....to tell you the truth i would prob save up and buy a k b/c you are going to dump almost as much money to build the d17 as you are doing the k-swap(i spent almost 5k on the built d17) and now i belive the swap is like 3k before k-pro but i would use a k24 not k20.....that is just my opinion im sure others will chime in
Live for the Twisties
Re: D17 Turbo
Like shwoogie said, you can get to your goal without to much difficulty with a quality turbo set-up, K-pro, i/h/e, and a stage 3 head. You wouldn't need to touch the bottom end, but at that point you putting a fair bit of strain on the engine and some reliability is inevitably sacrificed. I wouldn't want to go that route on a daily driver. The only real benefit is the ability to do the mods gradually, whereas a swap is all at once.
A k20a2 swap with I/H/E and K-pro could put you at 220hp at the wheels, with complete reliability. The disadvantage is that it would cost a little more and you need to spend all your money at once, but once your ready to go turbo on a k20a2 then you could make 500hp+ without much trouble.
Jaryn
May 17, 2016 02:52 AM
