D17 Turbo
Old Apr 6, 2011
Emmmm2's Avatar
Emmmm2 is an unknown quantity at this point
D17 Turbo
Whats up guys...
Currently im rocking a d17... heres the thing, i'd like to hit atleast the 200-300hp mark... I don't know very much about d series motors, but i was wondering if the motor was built if it would be capable of of handling enough boost for that power reliable?
I know i would be better off purchasing a k series, but i am lacking the cash right now, and i understand these can cost quite a bit in the end.
Old Apr 6, 2011
Emmmm2's Avatar
Re: D17 Turbo
just looking around it looks like some of you guys are hitting 400+ with these motors! i was checking out the internals sticky but i didn't see anything in the 1st post about em. What should i look at upgrading in this thing? How much boost would you have to run roughly for 250hp numbers?
EDIT: Just realized the posts go the other way around :P
Old Apr 6, 2011
garden772's Avatar
2001 Civic LX
garden772 is an unknown quantity at this point
Re: D17 Turbo
lol i was confused at first aswell i set it to the way i was used to, so that the posts get newer as you go down instead of get older as you go down
Old Apr 6, 2011
Emmmm2's Avatar
Re: D17 Turbo
I'm rocking an LX too man, any experience with coilovers? i'm kind of on the hunt for some but don't know what to get, i'd like to spend like $600
Old Apr 6, 2011
Re: D17 Turbo
the order of the posts have been asked a coupla' times:
https://www.civicforums.com/forums/1...backwards.html
https://www.civicforums.com/forums/1...-not-last.html
Turbos, i will refrain, i just know the theory behind, never did have them on my hands and not interested on them.
Old Apr 7, 2011
shwoogie420's Avatar
shwoogie420 is an unknown quantity at this point
Re: D17 Turbo
i made 282 on bone stock motor...well it had arp studs cometic head gasket and a crower stage 3 cam...i had a bad boost leak in the video when i was at the dyno but i got 282hp at 15psi.....it depends on what turbo you are looking to get and how good the tune is but if you get a decent size then prob 10psi will get you are 200-250....if you want 300+ then build the motor.....i now have a bulit motor b/c i wwas at 25psi and the rod finally decided to show it self to me.....to tell you the truth i would prob save up and buy a k b/c you are going to dump almost as much money to build the d17 as you are doing the k-swap(i spent almost 5k on the built d17) and now i belive the swap is like 3k before k-pro but i would use a k24 not k20.....that is just my opinion im sure others will chime in
Old Apr 7, 2011
MindBomber's Avatar
Live for the Twisties
Re: D17 Turbo
Like shwoogie said, you can get to your goal without to much difficulty with a quality turbo set-up, K-pro, i/h/e, and a stage 3 head. You wouldn't need to touch the bottom end, but at that point you putting a fair bit of strain on the engine and some reliability is inevitably sacrificed. I wouldn't want to go that route on a daily driver. The only real benefit is the ability to do the mods gradually, whereas a swap is all at once.
A k20a2 swap with I/H/E and K-pro could put you at 220hp at the wheels, with complete reliability. The disadvantage is that it would cost a little more and you need to spend all your money at once, but once your ready to go turbo on a k20a2 then you could make 500hp+ without much trouble.
Old Apr 7, 2011
Brian1037's Avatar
Sedans > Coupes
Brian1037 is a jewel in the roughBrian1037 is a jewel in the roughBrian1037 is a jewel in the rough
Re: D17 Turbo
Do people normally change their tranny when they turbo or swap engines? or can our trannies handle it?
Old Apr 7, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: D17 Turbo
Manual tranny is OK for turbo.. auto isnt
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Donahue
Sep 8, 2015 09:00 AM
KAMIKAZEEx
Aug 30, 2015 08:30 AM
justcruzin125
Aug 11, 2015 09:09 PM
