reassemble strut with coilover sleeve question...
Old Oct 15, 2010
Miyagi's Avatar
Miyagi is an unknown quantity at this point
regarding installing coilover sleeves on tokico struts -
Can someone tell me ..if you are supposed to compress the strut all the way down while you are tightening up the top strut nut? thanks.
Old Oct 17, 2010
Re: reassemble strut with coilover sleeve question...
?!? Compress the struts? or springs?
Old Dec 12, 2010
MindBomber's Avatar
Live for the Twisties
Yes, you are!
Thats called the spring retainer bolt I believe.
Old Dec 12, 2010
sl33pyriceboi's Avatar
no u dont need to compress the strut to put the top bolt on. just put the whole strut between ur legs and tighten the bolt. then when its gets real tight, hold on to ur top mount and it'll prevent the stem from swiveling
you only "compress" ur springs when it has a lot of load on the top mount. (because if u dont compress it, the spring will shoot the top hat out when u take off the bolt.)
with GC, the spring isnt long enough for there to be load on the top hat.
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
Bruce2
Sep 27, 2015 08:45 PM
