Sticky Throttle Cable
Old Sep 30, 2010
96coupe's Avatar
96coupe is an unknown quantity at this point
Hi Guys,
I have a couple of questions for people. I have a 96 DX Coupe with 250,000 kms and 5 spd tranny. My first question is that the check engine light is on, how would I check the code(s) without hooking up to a scan tool? The second question is the throttle cable seems to be stiff/sticky, I can't figure out whats wrong with it. When the car is off, the pedal moves fine. When the car is on and I'm driving, it seems stiff and then it seems to be fine the higher the RPM's go. I can't figure out whats wrong with it, hoping someone might be able to help me out.
Thanks.
Old Sep 30, 2010
lazlong's Avatar
Re: Sticky Throttle Cable
1. Go down to Autozone and have them read your code, it may still be stored. Autozone doesn't charge for scanning your car.
2. Check throttle cable for frays, nicks, kinks, etc.
3. Check your throttle cable freeplay, should be between 3/8"-1/2".
This is a pic of my '01 NOT a '96, but yours should look about the same. Check freeplay up near the throttle body about where my finger is:
4. If freeplay is out of spec, loosen the locknut:
5. Then turn the adjusting nut until it in spec:
6. There is also a locknut and adjusting nut behind the pedal too.
Old Sep 30, 2010
lazlong's Avatar
EDIT: Was reading some more: If the throttle cable is in spec and doesn't bind, operate the throttle by hand and look at the throttlbody and check to see if the throttle valve and/or shaft are too loose or too tight.
Tyler93
Mar 20, 2016 09:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Bruce2
Sep 27, 2015 08:45 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
Bricoleur
Sep 9, 2015 12:30 PM
