Dash/Instrument panel lights out after new stereo
Old May 24, 2010
jaytbee's Avatar
jaytbee is an unknown quantity at this point
Earlier today I installed a new stereo in my 2001 civic. Everything worked just fine during the day, then when I went out tonight and turned my headlights on, no instrument panel lights lit up (dash gauges, temp controls). After a few seconds, I heard some pops and snaps, then smelled hot wires. It's too late/dark to check anything out now. Have I just blown a fuse, or did I destroy the whole circuit? Headlights and turn signals all still work fine. New stereo lights up and plays fine, too. Does anyone have any ideas on how to fix the problem? I'll pull the illumination/dimmer wires in the morning when it's light, but I have a feeling that won't fix the problem. If I do find blown fuses, can I expect that to fix the problem, or is it likely that it's more serious than that?
Old May 25, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: Dash/Instrument panel lights out after new stereo
Well the illumination wire behind the radio burned up due to a short and the short blew the fuse. First repair the shorted wire and then replace the fuse.
Old May 25, 2010
CraigW's Avatar
What you heard and smelled was in fact your electronic dimming control circuit contained inside of your cluster saying goodbye.
Old May 25, 2010
electric130's Avatar
yep.
Old May 25, 2010
BlueEM2's Avatar
Whachya lookin at?
That's one expensive head unit
Old May 25, 2010
that sucks.
Old May 25, 2010
jaytbee's Avatar
I've just disconnected the orange wires and checked my fuses...none blown. So this electronic dimming control circuit, you say it's expensive. Are we talking like hundreds of dollars expensive? And how complicated of a DIY project would replacing it be if I decided to tackle it myself? Is it something that's best left to a trained person? I can get by with no dial and gauge lights at night (everything else works...indicator lights, ac, recirculation, and rear defrost lights...it's just the dials on my dashboard and temperature control lights that don't come on). Thanks for your help guys.
Old May 25, 2010
search around on here. there's threads about it as well as explanations on not connecting the dimming wire.
Old May 25, 2010
CraigW's Avatar
Some have been able to repair the damaged printed circuit trace.
The part is not sold separate only as part of the cluster.
Youngciviboy
Jun 10, 2015 03:49 AM
4 banger
Jun 5, 2015 01:44 AM
beveragemp
May 25, 2015 07:11 PM
Ma213802
May 18, 2015 07:01 AM
supercivic01
South
Nov 30, 2001 11:27 AM
