No Spark??
Old Dec 28, 2009
jun10r27's Avatar
jun10r27 is an unknown quantity at this point
No Spark??
Hey i have a problem at hand and i would like some opinions, im not getting any spark/power at all. it cranks and fuel is getting in. but no spark. brand new plugs. brand new coil packs. fuses are fine. All grounds are hooked up. Any ideas?
Old Dec 29, 2009
Re: No Spark??
is the green key light flashing?
Old Dec 29, 2009
jun10r27's Avatar
Re: No Spark??
Yup. Kpro Has it disabled
Old Dec 29, 2009
jun10r27's Avatar
Re: No Spark??
Any ideas man?
Old Dec 29, 2009
Re: No Spark??
well what exactly happened that caused it not to start?did you just install everything with kpro and now it doesnt start?
Old Dec 29, 2009
jun10r27's Avatar
Re: No Spark??
brand new build. everyhting was redone. fuel system. injectors. everyhting.
Old Dec 30, 2009
jun10r27's Avatar
Re: No Spark??
I have a 2002 civic. D17A2 Ok so i checked the continuity of the grounds on the coil pack plugs. they are all grounded.. they work fine. i turned ignition on and had 12v between the middle hole in the plug(ground) and the left Hole in the plug(Wire going to J/C C 102).the third one i tested to ground and had no continuity. tested to Power (Wire going to ECU) and got 6v. hmmm?gonna get a test light and see if i dont get a pulse when i crank it. i dont think i will. but then what? Crank Pos sensor? gonna check that too. im pretty sure its hooked up. it cranks and im getting fuel. and brand new plugs. all fuses are fine. maybe a relay bad? main relay 1&2 are fine. Anyhting else im missing?
Heres a couple pictures of the diagram hope this helps you Help me lol....
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
Styven Szastur
Sep 23, 2015 05:26 PM
pilebuck13
Sep 21, 2015 10:45 PM
Bman2212
Sep 2, 2015 11:49 AM
