No Spark??
No Spark??
Hey i have a problem at hand and i would like some opinions, im not getting any spark/power at all. it cranks and fuel is getting in. but no spark. brand new plugs. brand new coil packs. fuses are fine. All grounds are hooked up. Any ideas?
Re: No Spark??
well what exactly happened that caused it not to start?did you just install everything with kpro and now it doesnt start?
Re: No Spark??
I have a 2002 civic. D17A2 Ok so i checked the continuity of the grounds on the coil pack plugs. they are all grounded.. they work fine. i turned ignition on and had 12v between the middle hole in the plug(ground) and the left Hole in the plug(Wire going to J/C C 102).the third one i tested to ground and had no continuity. tested to Power (Wire going to ECU) and got 6v. hmmm?gonna get a test light and see if i dont get a pulse when i crank it. i dont think i will. but then what? Crank Pos sensor? gonna check that too. im pretty sure its hooked up. it cranks and im getting fuel. and brand new plugs. all fuses are fine. maybe a relay bad? main relay 1&2 are fine. Anyhting else im missing?
Heres a couple pictures of the diagram hope this helps you Help me lol....
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
Styven Szastur
Sep 23, 2015 05:26 PM
pilebuck13
Sep 21, 2015 10:45 PM
