airbag light is on and will not go off
Old May 6, 2009
karenpoop's Avatar
karenpoop is an unknown quantity at this point
My airbag light came on my 03 honda civic si and has stayed on. Took it to Honda dealership and they said the airbag system needs replaced and part alone is over $900. This is outrageous, does anyone know if it is possible I do not have to replace the entire unit? I cannot afford over a $1000 to fix this
Old May 6, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
Re: airbag light is on and will not go off
Your light most likely came on because of a loose connection in your SRS/airbag system. Is your car an American SI or Canadian SI? There is a way to reset your srs light your self using a paperclip:
https://www.civicforums.com/forums/1...srs-light.html
Old May 7, 2009
CraigW's Avatar
What was the diagnostic code ?? It should be on you paperwork from the dealer. A 7-2 and some others would be "SRS Control Unit" related.
My 05 had a module failure.
Old May 7, 2009
karenpoop's Avatar
Hi, my car is a Canadian car
Old May 7, 2009
karenpoop's Avatar
My code says 07-2, internal failure of SRS unit. I guess this is not good. I may have to drive with no airbags.
Old May 7, 2009
karenpoop's Avatar
It is a Canadian SI
Old May 7, 2009
CraigW's Avatar
Mine came on around 50k miles, It was a battle with Honda to end up with a 50%/50% at "Honda's" rate. Still cost me $500 with diagnostic. (they had replaced those crappy front struts twice) and thought they were doing me a favor at 50/50 for the SRS module.
You could try contacting Honda customer service if you remain calm and explain the problem they may help you with the repair (50%-100% coverage) You already have the diagnostic from Honda.
This has happened to a fair amount of 7th gens IMO. I would like to see a recall and get some of my $ back if possible.
Old May 10, 2009
karenpoop's Avatar
Thanks for the info, I am going to contact Honda. Let you know how I make out.
Old May 10, 2009
Does anybody know what would cause that? Im trying to come up with a DIY for fixing any srs airbag computer.
Old May 10, 2009
CraigW's Avatar
Most likely every year and model has a different module part #. (coupe/sedan, Side SRS etc...)
You will also never find a schematic other than the modules pin-outs to the car. This is not really a module to tamper with IMO.
Old Mar 23, 2010
bymitten's Avatar
bymitten is an unknown quantity at this point
I've seen a video on how to obtain the codes yourself with just a paper clip (and I'm NOT referring to the video on how to reset the srs light) ...
http://www.vehix411.com/tag/abs-code/
But my question is, where/how do I look up this code myself to see what the problem is? Is there an online documentation or something?
Thanks.
voblak2
20
May 4, 2023 02:08 PM
Burnout
Jul 15, 2022 10:24 PM
RIPSAW
Jun 9, 2015 08:33 PM
jimmyfloyd
May 20, 2015 07:06 PM
big20ugly
Nov 11, 2001 08:30 PM
