Suspension
Old Apr 19, 2009
PhilMize's Avatar
PhilMize is an unknown quantity at this point
Suspension
I have a 97 civic dx. and I"m looking to replace my stock suspension thats dieing slowly on me. I only wanna spend around 400-450. Can anybody point me in the right direction? I'd like adjustables cause I wanna drop it an inch or so.
Old Apr 20, 2009
felix_2k1's Avatar
felix_2k1 is an unknown quantity at this point
Re: Suspension
I think my eibach springs were around 350.00 if I'm not mistaken, They aren't adjustable but it dropped mine 1 1/2 inches.
Old Apr 20, 2009
felix_2k1's Avatar
Re: Suspension
Go to buyeibach.com. Cheap
Old Apr 20, 2009
ScottDR's Avatar
ScottDR will become famous soon enough
Re: Suspension
Adjustable coil-over types will cost much more than 4-500. If you still want a soft ride, go with a variable rate spring (like OEM) and a stiffer strut to make up for the stiffer spring.
If that's the route you are wanting to go, get some Eibach Pro-Kit springs (used to save money or around $200 new for a set). Then a set of KYB GR2 for about $72 each (or AGX for $99 each if you want to fine tune the ride to your liking). I'm sure there are plenty of other brands of struts that will also dampen those springs but most of my experience is with Koni's (read more $$$).
If you want something more the choices are limitless. Linear rate ERS springs (to the rate you want) on Ground Control coil-over sleeves is a good poor-man's version of full blown coil-overs as long as a good strut is used, like a Koni. Actual coilovers with linear rates can cost big money, but are really incredible.
Old Apr 20, 2009
ScottDR's Avatar
Re: Suspension
Oh, and if that's your car in the pic, nice DOHC and 99-00 front end swap
Old Apr 20, 2009
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
Re: Suspension
i have tenzo springs and stock struts. love the way it rides. lowers it more then a inch though. and my springs were only about 100 bucks
Old Apr 20, 2009
PhilMize's Avatar
Re: Suspension
yea thats me... thanx!
I was in a shop looking at some agx's they were like $390 something... they were the springs and shocks
I don't really know if thats a deal or not... I've never bought or looked into suspension before so im kinda learning as i go... I was looking on ebay at this tokico set http://tinyurl.com/dmzntk
also should I invest in a strut bar? rear and front? lower rear? I wanna get rid of wheel hop but I don't want to pay assloads of money for some stupid bar I could prob make from parts out of the junkyard...
Old Apr 21, 2009
ScottDR's Avatar
Re: Suspension
Don't spend money on strut bars (unless you just buy the Si front one from Honda-it's cheap, light and works better than most). It will not help wheel hop at all. You just need good springs/struts. AGX's with springs for $390 new? That's the price of AGX's only new, so I'm not sure what kind of springs they would come with.
Linear rates are by far better for feel (heck and for wheel hop) but most people don't like them because they give a slightly harsher ride. On my track/fun car I could care less about ride quality, only turning corners with a linear compression/rebound. On my daily driver I have Eibach Pro-Kit's because a) I know the company (since I use ERS springs on my fun car) and b) I got them for $75 used. My stock struts aren't quite strong enough to firm up the ride though. I'll be tossing AGX's on but that may be overkill as GR-2's would probably do the trick but I also like the ability to fine tune the damping rates.
Old Apr 21, 2009
ScottDR's Avatar
Re: Suspension
Oh...and watch out for AGX's on Ebay, KYB has warned that there are cheap knock-off's that come very close in appearance but aren't built with the same quality and you will have no warranty unless bought from an authorized dealer.
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
