Fake alarm LED
Old Oct 18, 2008
mdawg's Avatar
mdawg is on a distinguished road
Fake alarm LED
Whats the best option at approaching this. I've seen a few sites that used a blinking LED but I'm not sure how to wire it up to only blink when the car is off.
Old Oct 18, 2008
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Re: Fake alarm LED
why not just have it blink all the time?
Or:
http://search.ebay.com/fake-alarm_W0...dsreturnedZ300
Or:
You could use a relay. Not sure exactly how to hook it up myself, but relays have a normally open wiring option and a normally closed. If you wire it to normally closed and to your 12v accessory it should turn off when the car is on and turn on when the car is off. At least thats how I understand it.
Or see this technique:
http://www.nifty-stuff.com/car-alarm.php
Old Oct 18, 2008
Re: Fake alarm LED
well you could put it on a switch and turn it on when you leave the car. just an idea. otherwise you prolly need to use a negative switched relay or something and tie to the ignition.
Old Oct 19, 2008
Jza's Avatar
Jza
Jza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the rough
Re: Fake alarm LED
alarms are cheap, just install a real one. Not only will it let you know if someone is breaking into your car, but if something hits it as well.
Old Oct 19, 2008
mdawg's Avatar
Re: Fake alarm LED
Fully plan on it, but just wanted something temp. for another month or two until I got around to getting it. I have to much with the CarPC to try fooling around and installing an alarm right now. After it is completely in it would be stupid of me not to have an alarm
Old Oct 19, 2008
Re: Fake alarm LED
well then just get a 9v battery, a blinking led from radioshack, and a resistor for it. should last more than two months just leave it hooked up somewhere visible and try to hide the battery lol
Old Oct 19, 2008
mdawg's Avatar
Re: Fake alarm LED
Brilliant! haha is there any circuit that grounds itself when the ignition is off that I could use though? The led would **** me off if it was going off at night while driving.
Old Oct 19, 2008
tbaleno's Avatar
Re: Fake alarm LED
Put a hat or rag over it when you drive
Also, when you get an alarm, see if there are any out there that will insure your stuff. Some have like 100K guarantees that will cover if your car is broken into while you have their alarm installed.
Old Oct 20, 2008
electric130's Avatar
Re: Fake alarm LED
get a SPDT or DPDT 12VDC relay. hook the coil up to ACC power. then run the power for the LED across the NC contact of the relay. so when the car is on, the relay is energized and power is removed from the LED. turn car off, power goes to the LED.
Old Oct 20, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Fake alarm LED
CarPC details?
Old Oct 20, 2008
mdawg's Avatar
Re: Fake alarm LED
Originally Posted by DeX
CarPC details?
Lol In my sig
Old Oct 20, 2008
DDragon7's Avatar
Re: Fake alarm LED
In English please. lol
Old Oct 21, 2008
Re: Fake alarm LED
that was perfect english
Read the "Pole & Throw" section:
http://en.wikipedia.org/wiki/Relay
Old Oct 21, 2008
DeX's Avatar
DeX
Canadian, Eh!
Re: Fake alarm LED
Originally Posted by mdawg
Lol In my sig
I got the 700TSV. Good luck!
Old Oct 22, 2008
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
Re: Fake alarm LED
i understood it just fine
Old Nov 10, 2008
sp4rt4n's Avatar
sp4rt4n is an unknown quantity at this point
Re: Fake alarm LED
i will upload a relay diagram tomarrow.. my comp is acting weird it will make a lot more sense you will just need to buy a led module for the blinking.. you will also need a spdt relay you can pick one up at your local bestbuy for like ten bucks.. they usually have them in the install bay
Old Nov 11, 2008
sp4rt4n's Avatar
Re: Fake alarm LED
ok... buy a spdt relay, and wire it like this
86-> acc. (fused)
85->ground
30->contsant(fused)
87a->LED output.
connect the other side of the LED to ground
the led will stay on unless you buy a blinking led.
hope this helps
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
meicalnissyen
Sep 22, 2015 06:20 PM
Dawit Melese
Sep 11, 2015 08:25 PM
First Car
Sep 8, 2015 08:54 PM
