Cruise control light out. How to replace?
Old Sep 26, 2008
Intercooler's Avatar
Intercooler is an unknown quantity at this point
The pushbutton on the dash has it's light out. Anyone know the steps in changing it out and what bulb it is on an 01?
Old Sep 26, 2008
Re: Cruise control light out. How to replace?
open coin tray, remove single philips screw, yank out pocket and buttons piece, push out the cruise button from the back and unplug, look on the side for a twist socket and use screwdriver to turn it and unlock. you can buy the whole bulb and socket from honda, or goto auto store and buy naked bulb and just reinstall in the old socket by bending the wires around like stock. theres a light for the CRUISE letters and also one for the green ON light.
Old Oct 10, 2008
johnnyboy5000's Avatar
johnnyboy5000 is an unknown quantity at this point
My odometer LCD back light is out. Can't see my mileage at night. Has this happened to anyone else?
Old Oct 10, 2008
greeen01civic4d's Avatar
same concept, just remove ur cluster, find which bulb it is, and replace
Old Dec 28, 2008
jgg204's Avatar
jgg204 is an unknown quantity at this point
both the orange "Cruise" lettering and the green "On" lettering appears to be out. Does this probably mean that both bulbs are out, or would there be a fuse responsible for these interior backlights?
Old Dec 28, 2008
CraigW's Avatar
Most likely both bulbs are bad.
Old Dec 28, 2008
yeah, esp if the other dash lights still work. there are two bulbs in there just replace both.
Old Feb 6, 2009
ross3093's Avatar
ross3093 is an unknown quantity at this point
can you replace these with led bulbs?
Old Feb 6, 2009
eh ya but its tricky cause they need resistors. you could put the resistor on the power wire outside of the switch if you can find which one it is. that will save space because its very cramped inside. also, leds are directional so it will not point out to the front but to the side and will not be bright. the bulbs are not standard size either theyre mini and have their own base.
Old Feb 6, 2009
ross3093's Avatar
sounds tough what type of bulbs do i need to replace em?
Old Feb 6, 2009
well check ledautomotive.com i believe they have some led kits to swap them out,.
Old Feb 6, 2009
ross3093's Avatar
AWESOME MAN!!!!!! I have resistors and leds already from other "projects" I might give this a whack if it works ill post a DIY!
Old Feb 6, 2009
sounds good. i did my main dash with leds and it was not too bad, those lil switches and stuff are much harder. i did it once with blue leds and magnet wire but there is not much space at all. i dont even have them lit up now.
Old Feb 6, 2009
ross3093's Avatar
can you recall what rating resistors and leds to use,
Old Feb 6, 2009
well i used 5mm leds but really had to shave them down. the resistors depend on the led specs. you need to know the current, forward voltage, and total voltage. then you can use this calculator. actually you should look into using 3mm leds which are much smaller.
http://ourworld.compuserve.com/homep...Bowden/led.htm
GolNat
Sep 10, 2015 08:25 PM
rcolosi
Apr 29, 2015 07:48 PM
honkeydonkey
Electrical
Apr 26, 2015 08:27 PM
SSMatey
Apr 13, 2015 06:09 PM
thesushiboy
Apr 12, 2015 02:54 AM
