Wheel Shake Problem
Old Sep 18, 2008
xxxcivic2001's Avatar
xxxcivic2001 is an unknown quantity at this point
Wheel Shake Problem
Hello,
I haven't posted on here in a maybe a year but I'm having a small problem with the civic. It's a 2001 5spd EX (see list of related mods below). I re-installed my ingalls td yesterday and now I'm having an intermitten wheel shake at speeds above 55 or so. It seems to happen completely randomly, at some points, its smooth as butter, and then 2 seconds later without changing speed or anything, the wheel starts to shake back and forth. This just started after working on the car, the only thing I really did though, was take the front wheels off (not rotate) and reinstall them as well as remove the strut tower nuts to install the td.
I'm open to any suggestions on what to look out to figure this out. I've checked the tightness of all the lugnuts and strut mount and everything is within spec. The fact that the shake comes and goes is confusing me. It's also not brake related. Let me know what you guys think, i'll be working on it tomorrow morning, Thanks.
(Mods that could influence this?)
Eibach sportlines w/ tokico blues
DC strut bar
Ingals TD
Progress Rear Sway
Tenzo RS-5 17" rims with new BFG's
See attached pics of car
ID:	74875   Click image for larger version
Old Sep 18, 2008
Tragedy's Avatar
skate or die
Re: Wheel Shake Problem
Correct me if I am wrong. You re-installed your own camber kit, and have begun to drive without an alignment?
Old Sep 18, 2008
Haha no maybe I wasn't clear, i reinstalled my torque dampener. I'm not that noobish
Old Sep 18, 2008
firetyphoon1's Avatar
firetyphoon1 is an unknown quantity at this point
umm dude i have the same problem now it just randomly happens around 55-65 after this speed its fine umm i think i got a solution and ill do it for me tomorrow i think u just need proper air in each tire b/c i chekd it and mine are like 33-44 PSI but i have 17" and i think max should be 45PSI
Old Sep 19, 2008
hndrider's Avatar
hndrider is on a distinguished road
take of the wheels and make sure everything you touched is nice and tight.
Old Oct 12, 2008
cujo1400's Avatar
cujo1400 is an unknown quantity at this point
shake in steering wheel?
wheel balance
Old Oct 12, 2008
sicma99ot's Avatar
just a man with a civic
sicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of light
same problem here. changed my brakes and now it happens at random crusing speeds.
im thinking the wheels need to be balanced. and i have no tred left on my front tires.
Old Oct 22, 2008
imtek9's Avatar
imtek9 is an unknown quantity at this point
my civic does that also and it is because of a bent rim
Old Oct 22, 2008
imtek9's Avatar
of course that is assuming that your tires are balanced and the alignment is good also
Old Oct 22, 2008
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
I have the same problem. And the funny thing is I just got new tires put on at discount tire, along with a alignment and balancing! It didnt do it before that!
Old Nov 5, 2008
awinagainov 61's Avatar
awinagainov 61 will become famous soon enough
got the same on my 04. started happening after i put my tenzos on. like others said probably wheel balance/alignment
conspiracy90
Jun 7, 2023 01:01 PM
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
blaketippett
May 29, 2015 08:02 AM
RickyRocket
Nov 30, 2001 10:14 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
