helicoil
Old Jun 9, 2008
thesob40's Avatar
thesob40 is an unknown quantity at this point
helicoil
hey guys. When i was changing my oil the other day i noticed that the threading on the oil pan was stripped which is causing the oil to leak out slowly through the bolt...i dont feel like replacing the oil pan itself because and new oem one runs around 100 bucks. Any idea where i can find a helicoil that will fix this problem? ive searched all local autopart stores and online and cant seem to find anything. Any help would be appreciated.
Old Jun 10, 2008
hondaex08's Avatar
hondaex08 is an unknown quantity at this point
Re: helicoil
u can find that kit at most auto parts stores or even an harbor freight store . but from one tuner to another i suggest you spend the 100 $ it will be worth it in the long run . b cause every time you go to change your oil you have to remove that plug and a helicoil will not stand up for it . in the long run its worth the money or even check out ebay for a good deal on a oil pan
Old Jun 10, 2008
TRIZ's Avatar
Re: helicoil
partstrain.com or http://www.hondaautomotiveparts.com/
Old Jun 11, 2008
thesob40's Avatar
Re: helicoil
new oil pan it is then. thanks.
Old Jun 11, 2008
Re: helicoil
we carry them at advance auto parts in special job tools section.
Old Jun 14, 2008
sql_civic's Avatar
Re: helicoil
x2 on replacing the pan. But you'll need a new gasket as well so the price goes up.
Old Oct 19, 2009
deadair's Avatar
deadair is an unknown quantity at this point
Re: helicoil
Here's the result of a "professionally installed" helicoil. Set me back over $350 and IMMEDIATELY resulted in more damage than before it was "installed."
Old Oct 19, 2009
Re: helicoil
wow haha. helicoils are good but youre not supposed to use em like that! its for mild repairs that arent under any pressure. i used one on my seat bolt but it can come out pretty easily if i wanted to remove it. whoever did that must be a complete retard. im guessing you got a new head put on?
Old Oct 19, 2009
deadair's Avatar
Re: helicoil
My understanding is that helicoils can be legitimately used in sparkplug holes. I'm not familiar with the installation procedure, but suspect it's best done with the head off and by a shop.
Anyway, I've ordered a remanufactured head from an Ebay store. Pretty good deal: $230 and no core charge.
http://motors.shop.ebay.com/elnieves...1&_from=&_ipg=
Old Oct 19, 2009
Re: helicoil
there is no way the coil will stay put in an engine. usually threadlock is used to hold them in place, and even that is not a pernatent solution but its usually okay for normal applications. i wonder how many metal shavings got into the engine and caused even more damage when he did that first repair. i know when i did my seat bolt, i had a huge mess of shavings all over the floor from tapping.
Old Oct 19, 2009
deadair's Avatar
Re: helicoil
Yeah, that was my concern too. However, I didn't see any unusual residue in the combustion chamber (other than the helicoil, of course), so I guess the shop at least did that part right.
Old Oct 28, 2009
SatyaK's Avatar
SatyaK is an unknown quantity at this point
Re: helicoil
You can find all helicoil tools & thread repair kits on
http://www.helicoil.in
popefelix
May 21, 2013 01:19 PM
filcard
Feb 26, 2012 08:46 AM
Hitchhiker42
Feb 9, 2011 12:41 PM
nick951
Jan 17, 2011 09:49 AM
Boilermaker1
Mid Atlantic
35
Jul 12, 2008 04:35 PM
