My AC system has been removed!
Old May 15, 2008
hongkonghippos's Avatar
hongkonghippos is an unknown quantity at this point
I recently bought a 2000 civic hx with an si motor swap, and I was stupid and didn't realize that the the previous owner took out the entire air conditioning system before he sold it to me! (I've never seen under the hood of a civic before, so I thought the radiator was just really small; I didn't know that the huge empty space next to it was supposed be the ac compressor).
I compared my car to my buddies 1997 civic ex, and the only thing I have from the ac system ac is the button in the center console. Now it's 100 degrees in the Bay Area, and I'm cooking in my car.
I seriously need ac. What are the parts I need to buy?(Compressor I know, everything else I have no idea) And how much would it cost to install?
I'm considering going to junkyards/salvage-yards to get the parts myself, then getting it installed at a shop. If not, I'm also open to getting the whole thing done by a professional shop. What kind of hit is my wallet going to take on this?
Old May 15, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
Re: My AC system has been removed!
Here's the parts schematic for the compressor:
Condenser:
AC Cooling Unit:
All the pipes/hoses:
All these schematics are from a 2000 Si, I figured that's what you'd be going for if you've swapped in a B16. These should help if you go to a junkyard, just to make sure all the parts and nuts and bolts are there. I'd get a good look at your buddy's setup and take pictures, so you know what to pull off of other cars. If you know a good shop, go talk to them. The mechanic that's going to work on it can talk you through what to get. If you take it to a dealership, I bet they'll tell you you need all new parts, which will total $2649.99, plus any tax or labor they'd care to assess. So yeah, junkyard parts and a shadetree mechanic are going to be the way to go here.
I don't know exactly how much these parts are going to cost you, but I bet a Pull-your-parts yard is going to charge you for the four chunks I showed you (Compressor, Condenser, Cooling Unit, Hoses), and I'm not completely sure how much it's going to cost, so I'm not even going to guess. I'm guessing that if the previous owner took out the AC, he left the harness intact. If that's the case, this shouldn't be too much work, just replacing what he took out.
All is not lost. You can fix this.
Old May 16, 2008
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
I believe there is a couple of kits floating around out there for about $900
Old May 16, 2008
TRIZ's Avatar
Contact the seller and ask where your AC is!!
Old May 16, 2008
lol you wont need ac in bay area, this is just a short heat wave, normally its maybe 60s the whole summer.
CarStuff
Dec 6, 2020 12:52 PM
jtdunn4life
Oct 27, 2015 03:33 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
WaryDriver
23
Jul 22, 2015 07:18 PM
02Si
Dec 9, 2001 07:37 PM
