SRS Diagnostic Code 9-3
SRS light is on. Paid the dealer $115 to diagnose it (probably 5 minutes work) and it came back with the diagnostic code 9-3 which means the driver's side seatbelt buckle is faulty. Price to replace it is over $300 plus tax. The part is $225 plus labour.
I know how to reset the light per instructions elsewhere in this forum but the light comes back on so the buckle really is faulty.
Anybody else ever have this problem and can recommend a lower cost solution?
2002 Civic.
2002 Civic.
Re: SRS Diagnostic Code 9-3
I'm not sure if a standard OBDII reader will get SRS codes or not ??
If you get it read, post your results.
I have an 05 the light came on at 52k miles with a 7-2 "internal failure of SRS control unit" Estimate $1000
Anyone else with a 2001 Civic have this reading issue?
the SRS light is a service engine soon light (it's kind of like a warning light), which is different from the standard Check engine light. That is why the standard OBDII readers can not read them.
SRS is the system for the airbags and seat belt pre-tensioners. It does a system check each time the car is started, an SRS light signals a problem detected in the system.
Honda won't replace my seatbelt for free. I called them and they are retarted. They only replace it with factory defects and stuff nothing that has to do with SRS unless your under the 3 year warranty. OBD scanners cannot read SRS lights because they only work on engine codes. You need a special honda computer to scan for the SRS code. You can get cheaper parts online though and just get it installed so you don't have to pay a lot for the parts.
2002 Civic.
2002 Civic.
OR you can just buy a reader OBDII <== i think thats what you call it. which cost $55..
just google it around find a way to fix that buckle probably since you KNOW the code..
you should never take your car to dealers unless its a HUGEEEE problem even mechanic give up..
I have an 03 civic, and the SRS is on to. When I reset it, it comes back on shortly after. I am thinking about buying an OBD ii reader. Any tips? There is one on sale at canadian tire for $59.99.
Check this out. I have yet to try it myself but I figured it would help and sure save people some $$$ ...
http://www.vehix411.com/tag/abs-code/
holly crap!!! 115 just to diagnose it..!!! you coulda take it to some shop tell them you have some yellow light on "act dumb " ask them what is happening.. then they probably read it for you for free..
Only place i could find that reads SRS are the dealers. Went to several shops to ask and they did not have readers for SRS.
Unit had to be programmed after install too, which raised the cost. Unit itself was 470.
Go to
http://forums.clubrsx.com/showthread.php?t=636707
for tutorial how to retrieve SRS code. I tried it and it works on mine 2001 Civic Lx. My problem was 9-3 i.e. faulty driver side seat belt buckle. I have an appointment with Honda on next Monday. Lets see what do they say. On phone however they said that if buckle is faulty it is covered by Honda's life time seat belt warrenty. Lets See.
Caution if you try to diagnose the SRS error by sticking wires or paper clips into the OBD2 connector! If you connect the wrong pins it can cause problems. Ask me how I know this... I'm assuming you asked, so here's how I know:
After I successfully diagnosed my car with a 9-3 code, I thought I was an expert: using a paperclip to diagnose a car instead of paying the dealer $100+... man would MacGyver be proud. With my newly inflated ego, I pestered a friend to let me "help" him diagnose his SRS code. I plugged the paperclip into the wrong sockets! The paperclip got hot and I pulled it back out. I connected battery power to the signal ground. The car wouldn't start. Luckily, I only blew the ACG (S) 15Amp fuse. I don't know what ACG (S) stands for, but I was lucky I didn't blow the computer. I was really sweating out my dumb mistake until I found the blown fuse.
The pinout diagram for the OBD connector is symmetrical and could be interpreted the wrong way (by me at least). Ask yourself: are you looking at it WRT the wire side or the side where the OBD2 scanner plugs in?
After finding and fixing the blown fuse (2 days later) I was too scared to diagnose my friend's car. He said he was still going to do it. I am officially retiring my paperclip.
Took my 2003 to the dealer with the 9-3 airbag code today. The service writer indicated that the belt buckle is replaced for free under warranty if, and only if, the dealer finds it can't get the buckle to engage properly. I don't know why, but a faulty electrical circuit alone (which is what I think causes the airbag light) is not enough to trigger the warranty according to Ed Morse Honda.
Fortunately, my driver's side belt buckle is very difficult to engage and the dealer agreed to replace it under warranty. The part alone would have been over $200 if I had to pay for it myself. I noticed, though, that there's a you tube video here on how to fix the belt switch and reset the airbag light.
I created a profile just to inform you fellow civic drivers of how to diagnose this issue and potentially resolve it. After doing the research, I ended up saving $100 on the diagnostic fee. I rather Honda not receive that money because dealerships are banking off of this common issue.
It will be your responsibility to ensure accuracy of this information. You assume all liability.
I had the same issue on my EP3 2005 Honda Civic. The SRS light would stay on and not turn off. This prevented me from getting my inspection sticker.
Mainly after watching this video, I learned how to do it:
http://www.google.com/url?sa=t&rct=j...69620078,d.aWw
https://www.youtube.com/watch?v=Yv0KNcoGE-E
DIAGNOSE:
1. Locate the diagnostic connector under your steering wheel. Usually, this is located closer to the center of the car.
2. Insert the paper clip in PIN #1 (from the top right) and PIN 4 (from the bottom right)
3. Insert Key and turn two clicks (not turning on the car)
4. Observe the SRS light. It will turn off. Once it turns back on, count how many times it blinks. It should give you a one set of 1-second blinks and one set of fast blinks. Example: If it gives you 9 each of 1-second blinks, and then 3 fast blinks, then you have a CODE 9-3.
A Code 9-3 can mean that your seat belt buckle sensor is faulty. Before attempting to fix it yourself, call Honda and see if it's covered by warranty. Seat belts should be covered for free under warranty. However, I read that electrical harnesses are not covered and if they blame the electrical harness then you could end up paying $250-300 (for diagnostic fee and replacement).
Alternatively, you could clean the sensor using contact cleaner. This may void the warranty though, if you have one.
SEARCH TAGS:
Honda Civic Accord SRS light on air bag light seat belt buckle 2001 2002 2003 2004 2005
Resetting the SRS light is easy. there are a lot of youtube videos and post on this already so I won't need to explain. Good luck
DIAGNOSE:
SEARCH TAGS:
old thread, but new car for my daughter. so I clear the air bag light. a day or two later it is back. paper clip method gives me a 9-3 code. question... if the actual seatbelt light comes on and off with the seatbelt how is the switch bad?
3 wires.
The seat belt light operates using one of those two sets of contacts.
The SRS control unit uses both sets of contacts. If one set of contacts fails to work correctly, you get the warning light and corresponding fault code.
HTH
2002 Civic.
2002 Civic.
Two years ago I had the same problem the dealer replaced the buckle for free.
I know that this is an old post, but since I was reading it for guidance in 2019, figured I'd chime in - it's my understanding that for vehicles that old, Honda still offers a lifetime warranty on anything relating to the seatbelts. I just called the dealership and they confirmed that, for my 2005 Honda Civic, if this code (SRS 9-3) really indicates a seatbelt problem, they will fix it free of charge.
Also, this YouTube video offered great instructions on how to read this code without a code-reader, worked great for me
VTEC2002Civic
Nov 16, 2017 08:21 AM
Kennykenny
Dec 5, 2013 09:43 AM
2k1_Toaster
27
Aug 6, 2012 08:50 PM
DieMaster
Aug 5, 2008 08:51 PM
