sounds on 2000rpm/2500rpm
Old Mar 1, 2007
DaSilverCivic's Avatar
DaSilverCivic will become famous soon enough
tried searching no result. don't know what other words to put at the search . . .
heres the problem. . . . i've been carefully listening to my car and i've noticed, that when the needle on the rpm gauge hits 2000rpm sometimes 2500rpm, there is a slight swishing sound. it's kind of hard to describe, something like air passing through???? (not loud, can only hear it if you pay attention) this sound only happens when the needle is on the 2000rpm and if not, on the 2500 rpm. anyone know of this???
btw, it's an 01 coupe ex
thanks in advance
Old Mar 1, 2007
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
never heard of this. the only guess i could take is that it might be the air going into the engine. probably not right, but tis the only thing i can think of
Old Mar 1, 2007
ronaldo9's Avatar
This is very strange like the previous post said. Do you have a header by any chance. Bc that sound you describe sounds like air pinging inside the header when u step on the gas. I don't know please describe more if you can.
Old Mar 1, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
any mods on your car ?
Old Mar 1, 2007
DsevenEm2's Avatar
This is Myspace
Maybe Its Ur Turbo! Or Maybe Ur Car Has Asthma!!
Old Mar 1, 2007
HondCivc91's Avatar
HondCivc91 is an unknown quantity at this point
i know the sound. I posted up when I had my car with only 1,000 miles on the odo (it's an 05 ex coupe - now with 27,000 on it). I don't think it's anything, because I've heard other EM2's with the same sound when accelerating.
Old Mar 2, 2007
mods . . . aem sri, hpracing exhaust. (nothing great)
yes it happens when i accelerate. i can also hear it when i'm in neutral and i slowly rev it. again i only hear it ON the 2000 rpm and sometimes the 2500rpm. below and over sounds fine
the swishing sound does sound like air, and a very very very low zzzzzzzzz-ing sound???
Old Mar 2, 2007
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
First thought was it was the Vtec transition from low to high cam. But isn't 2000rpm too low? I thought 2800rpm was minimum. Most tachs aren't acurate but it won't be 800rpm off.
Some people claim to hear a similar noise at about 4500rpm. I think the consensus is that it is a sweet spot where the air flow is just right. Maybe 2000rpm is the sweet spot for the low cam.
Old Mar 2, 2007
dalaw's Avatar
Bone Stock!
i have an LX and i do have this hissing/metallic whining/supercharging sound at around 2000 and 2500 rpm, but my throttle has to be at a particular opening to have that sound to occur. I like that sound though
Old Mar 2, 2007
Da1lyDr1ver's Avatar
that sound you're hearing is air bubbles passing throught your heatercore. its very common for our cars and its not big deal, more of an annoyance than anything.
Old Mar 2, 2007
sweet . . .as long as it's not a bad thing. i guess i'll have my mechanic check it out just in case. thanks all
Old Mar 30, 2007
Re: sounds on 2000rpm/2500rpm
just got my car back from the mechanic for maintenance and for the check engine light to be fixed. apparently it was an o2 sensor that set me check engine light on.
anyways, found out that the rattling noise that i was hearing at 2500rpm, it was the catalyc(sp?) convertor shield that was loose. apparently after so much scraping it ripped off one of the bolts. had to be replaced, don't want my car to get on fire. just an fyi.
Old Mar 30, 2007
HyeHonda05's Avatar
Official Wish He Knew It All
I HAVE THIS SAME WEIRD NOISE TOO...I have an 05 Lx Coupe with a K&N SRI and an HKS HI-Power Axleback...this noise just started happening to me like 5 days ago, after I put my intake on.....I have no clue what it is either.......
Old Mar 31, 2007
Smile Re: sounds on 2000rpm/2500rpm
dude, that rattling noise that I hear d was the catalytic (sp?) convertor shield. hopefully that helps you and that you don't go crazy trying to figur it out if our issue is the same. my car is lowered to the point that I practically scrape a lot. I assume I scrapped too much that it loosened thae shield. too replace it it's about a benjamin. if this is not the case for hope you find it.
Old May 29, 2007
Nortron's Avatar
Nortron is an unknown quantity at this point
Wow I have a similar problem.. My car (02 lx) is lowered too a little, so it could be the catalytic converter.. I'll have to take a look.. The noise that mine makes is really loud though.. and rather BAD. doesnt sound good. people always look at my car like wtf when it makes that noise, its almost like something metallic is ripping. its on and off between 2k and 3k rpms and the accelerator has to be at least half way in or so. initially i thought it was my exhaust manifold cuz i know it was leaking some air.. so i took it off, replaced the gasket, sealed it with some gluey stuff but the noise hasnt changed a bit.. anyway ill try the converter this weekend.
Old May 29, 2007
TRIZ's Avatar
I have the same sound, only started after I upgraded my exhaust.
EDIT- forgot to say that it happens usually when i'm entering traffic and my engine hasnt warmed up yet- usually in the first mile or so, but only when accelerating. Sounds like some nitrous turbo kind of sound to me
Old Jun 16, 2007
95speedT's Avatar
95speedT is an unknown quantity at this point
just get a turbo and it will sound normal...haha
Old Jul 13, 2008
khmer's Avatar
khmer is an unknown quantity at this point
What was the part number for the heat shield? I lower my car at one point in time. It makes metal on metal sound, almost a sputter sound when accelerating from 2000-3000 rpm.
Old Jul 13, 2008
mrbanhbao's Avatar
mrbanhbao has a spectacular aura aboutmrbanhbao has a spectacular aura about
i got the same **** too. but i think its one of the belt kus i hear it when i warm up my car in the morning and open my hood. its coming from the belts.
Old Jul 18, 2008
Dirty4Door's Avatar
Dirty4Door is an unknown quantity at this point
I have the same thing noise. except my "buzzing" happens every time i accelerate. i took it in to Honda when I still had a warranty and they speculated that it could be rocks on the heat shield rattling around when significant vibration occurs or something like that.
So I took my sister-in-law's civic for a spin to compare noises (05 ex sedan, same as mine, from the same factory: denver, about a month apart). it turns out her civic sounds the same as mine: buzzing upon acceleration...
I still complain that it sounds like some kind of pressure leak, which is accompanied by a brief "ring twirling/winding down" sound upon high rpm up-shift.
EDIT...and it's they both are autos.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
