Need some camber help!!!!
Old Jan 18, 2007
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Alright guys I have an 02 Ex I put eibach sportlines on it, with a camber kit. The camber kit I have isnt enough now to pull it back out to 0 on the front. What have you guys done once the bolt thing on the front ran out of adjustment??? Thanks
Old Jan 18, 2007
Zzyzx's Avatar
Autocross Junky
Sounds like you have the car lowered a whole hell of a lot. Dut dont worry about it, as the OEM spec allows for -.75 deg camber on the nose. 0 Deg is horrible for every thing but drag racing...
You may want to read this...
Old Jan 18, 2007
TRIZ's Avatar
your going to want to rep this guy^
Old Jan 18, 2007
Well I just have the eibach sportlines on there which are only supposed to lower 1.4" but they just seem to keep getting lower, I've had them for probably 3 or 4 years now. Anyway last time I get the car aligned they were out of adjustment on the front. So now I really need an adjustment cause the front is wearing my tires out on the inside and I just swapped it to the back which is even worse camber so I need to get it adjusted. But I dont have anymore adjustment on the front. So what can I do?
Old Jan 18, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Thats toe, not camber. Camber doesnt really "eat" tires, its the toe that does it.
Post the specs or scan the sheet from the shop.
On the other hand, if you've had the same tires for 3 years, yes, they'll show camber wear and there isnt much you can do about that other than replace em.
I'd say anything less than -1.5 degrees on the front is fine for daily cruising.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
