yeah yeah, what is up with my Tranny!! Shaking!
Old Jan 17, 2007
Mr. Fantastic's Avatar
Mr. Fantastic is an unknown quantity at this point
ok, so before you go off on me i did do a search. Seems people have had this similar problem. I have a 2004 LX sedan manual with 33,000 mi. My car shakes from moderate to violently when i drive from neutral to 1st, and 1st to 2nd. It started to do it sporadically but now it does it more and more. It tends to not happen when i first drive the car out for the day or night but as i break in the car throughout the day, this is when it gets worse. I really believe it is the transmission but on other posts i heard it may be the engine mounts. I had a regular maintenance done on my car for the required 30,000 mi checkup and when that was done the car was driving like new , but after a week the car started shaking again. I told the dealer about the problem and they said that they could not find a problem. Damn! Any thoughts on this would be helpful before i bring it in again to the dealer. thanks.
Old Jan 17, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
check the mounts to see if there is any damage or wear on them..most cars with swaps rattle more than a didlo cause they use aftermarket mounts.
Old Jan 17, 2007
AmbulanceMonkee's Avatar
Try another dealer, or an independent shop. The may not be finding any problems because it's under warranty, and they'd have to fix it for free. Tho, that shouldn't matter, 'cause the dealer would still get paid, just by honda and not you.
Old Jan 17, 2007
sql_civic's Avatar
^^ X2. Dealerships aren't always what they should be cracked up to be. It all depends on who puts their hands on your car. Find a good independent that knows Hondas. They're out there.
Old Jan 17, 2007
sql_civic's Avatar
Just thought of something... Check if all your plug wires are attached properly. My engine had the shakes once and it turned out that a plug became defective and the engine was losing compression. SO check you plugs and wires. Easy enough!
Old Jan 18, 2007
koo, thanks i'll see what happens this weekend.
Old Jan 23, 2007
drjvic04's Avatar
drjvic04 is on a distinguished road
Um... How do your tires look? I had the same problem and I also needed new tires. Bought new tires and the problem went away. I thought it was the clutch but noticed that it was when tires were cold that it would slip or shake.
Old Jan 24, 2007
DDragon7's Avatar
I think he means that its a rocking back and forth feeling. Is that right?
Old Jan 25, 2007
nah, i just got brand new tires ,all four, and it still has the shakes. And its not a rocking back and forth its a real nasty vibration.
mistahlorax13
21
Nov 18, 2015 12:47 PM
Solo Flow
Oct 4, 2015 07:52 AM
speedlever
Sep 24, 2015 07:18 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
rainman15
Sep 6, 2015 11:10 AM
