P1361 Code - Help!
Old Aug 3, 2006
510racer's Avatar
510racer is an unknown quantity at this point
P1361 Code - Help!
This may have been covered before but...
Let me give a little background.
I replaced the timing belt, drive belts, water pump, and plugs over the weekend.
Ran fine until I started home the next afternoon. With the A/C on and the cruise doing about 73mph the engine warning light came on and I lost power. (The engine was running but no pull and occ. misfire) Turned it off, cranked it back up and drove home no problem. Yesterday, it did the same thing but I could get it to repeat if I had the A/C and cruise on. I stopped by an Advance and the scanner gave a P1361 code. I looked this up - seems to be an intermittent TDC or Cam Position Sensor Problem. Now its missing and the plugs are fouled. So, before I start throwing parts at it or mess it up worse I wanted to see if someone else had any similar problems.
Thanks!
Guess it would help if I tell you what kind of car.
2002 Civic EX 4dr. with about 120K miles.
Routinely maintained mostly by me.
Old Aug 5, 2006
streetglower's Avatar
well first off check to see if the connection may be loose or not even connected. also check the wires. if anything if you have a DMM let me know and I can guide you throuhg the testing for the sensor.
Old Aug 10, 2006
510racer's Avatar
P1361 code - TDC Sensor
I admit ignorance to say i don't know what DMM means.
I tried cleaning both the cam and crankshaft position sensor connections to little avail. I've about decided to go ahead and replace the cam position sensor just haven't got around to it.
Thanks for your help!
Old Sep 3, 2006
ryangt's Avatar
ryangt is an unknown quantity at this point
I have this same code right now, cannot get it to stop dying on me. All i have found is its a TDC intermittent sensor problem. Anyone have a clue as to what it is?? It has only happened when its been hot outside so im really baffled as to whats up.
PLEASE HELP im stranded untill i get this fixed.
Old Sep 3, 2006
have you tried replacing the sensor?
Old Sep 3, 2006
ryangt's Avatar
no ive been stranded here, i was just seeing if anyone has replaced it and fixed the problem..... stranded on labor day weekend, how crappy is that. No honda dealerships are open on labor day are they? IF SO does anyone know how much a TPS runs? And how hard an install is?
also i didnt atempt to replace it yet, because of the whole not throwing money at an unknown situation.
Old Sep 5, 2006
510racer's Avatar
The cam position sensor is about $50 from a dealer who is about the only place that can actually get them. I replaced mine but it didn't solve the problem. You'll have to follow much of the same procedure for changing a timing belt to replace it at least to the point you can get the top plastic cover off. My problem turned out that an alt. bolt hadn't got tightened good arced and messed up the ecm. Big $$$.
Old Sep 5, 2006
ryangt's Avatar
arced, thats ghey? I wonder why mines messin up, it says its intermittent
Old Aug 2, 2019
Jowny_'s Avatar
Jowny_ is an unknown quantity at this point
Re: P1361 Code - Help!
Same problem on my 2002 civic lx, one thing i noticed is that when it overheats it dosnt always show it on the heat gauge. But in the past i have seen the gauge go all the way up to read before the engine shuts itself off or loses power, the code i got after overheating was a tdc sensor or camshaft code. My best (uneducated) guess would be improper engine ignition caused be engine over heating. Hope this helps. Ps make sure both ur rad fans are working lol
Old Aug 2, 2019
Slumpertcivic's Avatar
Your best bet might be to stop guessing.
Driving any engine to the overheated point it shuts down is never good.
Old Mar 1, 2020
Darryl Robida's Avatar
Darryl Robida is an unknown quantity at this point
These engines don't shut down when they overheat, they melt down. So if you pull a gravel load up 7% grade at 110 degrees fahrenheit, with a partially clogged radiator and misc supplies in the cabin, the gravel rides in your harbor freight custom body trailer. With this very configuration, you will be alright, But no more than 1/4 yd of dry pea gravel, or DG/rock dust, Please. What you have to do is keep an eye right on that temp gauge. Your running a supercritical, positive feedback loop which tends to be quasi stable, if any little thing goes wrong. that gauge will go from normal to red in 3 to 4 seconds, that is how close to the limit you have come. So, shut down, immediately, or you will notice lots a smoke in the rear view mirror. even parts will come out the back. This will require a JDM engine import, swap out, best two get two on a single pallet, spare. These little hondas have set limits, There is not so much room for playing around. The thrill of summit victory will never fade.
GotU420
Sep 10, 2018 07:09 PM
Alpha 5
Jul 22, 2012 07:29 PM
IRPancake
Oct 8, 2009 12:21 PM
newellsb
Nov 19, 2007 03:11 PM
sleepy-racer
Buy, Sell, & Trade - Archive
Mar 1, 2007 08:47 AM
