Installing Fog lights gone horribly WRONG, NEED HELP
Old Jul 31, 2006
lsr_soul's Avatar
lsr_soul is an unknown quantity at this point
THis past weekend, I bought some Fog lights from EBAY(yes, i know i shouldn't have, but i tried it anyway). and everything seemed cool through most of the installation. But when i tried hooking everything up(while following instructions), something burned up. Now the back like for my gauges on my Tach and Speedo are off(and all the needle's lights are off too) when I use my parking lights or headlights. only the temp and gas gauge light works, all the little lights work too.
I figured if there was an electrical problem, the fuse would popped, but it didn't. It just let the electricity through and now I am stuck where I am. Nay help you guys.
-Did i burn some wiring, or is it the lights behind the cluster gauge(if any).
-Do i need to buy a new cluster gauge?
-don't really have many options left, might have to take to dealership. Will this void warrenty if i tried to install?
-speaking of which, the cables for the foglights that i have came up short, so i also need to find a way to extend them, but first the cluster gauge needs to work, cuz i can't see how fast i am going at night....=\
anyhelp would be great fellas and gals.
bump
Old Aug 1, 2006
drunkenmagnum's Avatar
sounds like a fuse but u said u checked that so i dont know. have someone look at it before u take it to a dealer if u r worried
Old Aug 1, 2006
lsr_soul's Avatar
well i took it to my school and we checked all the fuses and such. all checked out fine. we whipped out the ETM and checked out the diagram, it appears that there is a CPU that controls the lighting. So yeah im pretty ****ed, so my best plan is to take out the foglights and say some wierd **** happened with the car one night, its still under warrenty i think, 3 years or 50k if im not mistaken right/
Old Aug 2, 2006
Powershift's Avatar
Holler!!!™
Powershift is a name known to allPowershift is a name known to allPowershift is a name known to allPowershift is a name known to allPowershift is a name known to allPowershift is a name known to allPowershift is a name known to allPowershift is a name known to all
good luck!
keep us posted! I just got foglights from ebay too! I got OEM style though!
Old Aug 2, 2006
get universal fog wire harness from www.suvlights.com
for cluster, there are 5 bulbs in the back. try to replace the ones that are off, maybe its just burnt bulb? they just twist off the board and you can change it.
Old Aug 2, 2006
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Do you check your relays?
The little square boxes like fuses on the engine bay fuse box and below your dash
Old Aug 2, 2006
shmik1's Avatar
3yrs/36k I believe.
Old Aug 4, 2006
lsr_soul's Avatar
thanxs guys for all the help, i haven't had time lately, but this weekend ill check the lights in the back. and yeah ill buy the wiring harness from that site if it is only a bulb problem, and if 3/36k is the case, i still got about 5k in her. thanx again.
Old Aug 5, 2006
Da1lyDr1ver's Avatar
i believe the factory warranty is actually 2 years/24K miles. the warranty goes to 7 years/100K miles if you get the extended warranty.
try to change the bulbs in the back of the cluster like Gearbox said, and check the relays. its a lot cheaper than going to the dealer (last resort).
i've installed the ebay foglights on my friend's coupe before. the wire harness does fit, but like you said, it is a stretch. i thought it wouldnt reach before too, but if you guide the wire in the "straightest" line to get through the firewall, it will just barely reach.
Old Aug 5, 2006
Powershift's Avatar
Holler!!!™
how hard it to make the harness go through the straightest?
I'm installing mines soon!
Old Aug 6, 2006
if you guys are having problems with the crap ebay sends, just buy a new harness from suvlights.com with relays. easiest thing ever to hook up. just power and ground, then one power to each light, and ground the light. then one turnon wire like parking light or a switch. super easy. i used it to wire my hids in about 30 mins.
Old Aug 6, 2006
gizcivic's Avatar
gizcivic is an unknown quantity at this point
just run the wires through the driver side fender it will fit
i put my switch next to the cruise control
Old Aug 11, 2006
lsr_soul's Avatar
well ok bad news..........my parents finally found out that i did something to my car....so now they just want me to take it in tommorow morning, first thing, and if what you say is true about the warrenty, then there is no point to make my car look like stock ( might as well leave the evidence where it is and fess up) make it easier on the tech that has to fix my problem.......well i want my car back to normal, at first blown out lights for my gauges looked awsome at night(so dark) but i miss seeing the needles and the colors. anyways ill pay for it, im hoping its just blown bulbs ( won't be expensive) but labor(OMG that is HIGHWAY ROBBERY), and if not those, then its the CPU and computers are expensive. meh......last time i buy crap**ahem**great merchandise from ebay** for my car that is...... well thanks for all the help you guys.....
Old Aug 11, 2006
well the bulb is easy to change. it takes 5 minutes and they are gonna charge an hour just to look at it. or it might even be a fuse. i would check yourself before taking it in. they might not even find the problem. and why leave evidence? put it back to stock take off all the fog light stuff and say idk what happened the gauge light is out. they theyll fix under warranty.
Exterior
Nov 28, 2025 05:23 PM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
disaster
Nov 7, 2001 05:30 PM
