civic headlight wiring
Old Feb 9, 2006
civic bum's Avatar
civic bum is an unknown quantity at this point
Unhappy civic headlight wiring
i need help and don't know anything about the wiring harness. i have a '01 civic and theres something wrong with the headlight wiring now. when i had my stock halogens in, regular light was emitting from the driver side and very low lighting was comming out the passenger side. i changed them out and they were still doing that. then i bought some bi-xenon real HID by McColluch and only the driver side Hi-beam works. nothing else works. i took it to Honda and they said they tested the power and said power is comming out of both headlamps. they dont know what they're talking about. thats why i need anyones help who has had or knows how to fix this problem. thanks
Old Feb 9, 2006
maybe just buy a new wire harness and put that on so the bulbs get power direct from the battery. it should work so long as the switch wire works. www.suvlights.com
if worse comes to worse and that doesn't work, you can just run your own switch for the harness and put it inside and just use that to turn em on.
Old Feb 9, 2006
CraigW's Avatar
I have the headlight wiring info for the 01 that I printed for someone here. If you want it let me know and I will scan it for you.
Old Feb 9, 2006
it might also be a bad combo switch. i know 01-02 cars had a safety recall. mine was fine but others would burn out the wiring and one or both headlights just go off.
Old Feb 9, 2006
7thGenerasianCivic's Avatar
www.suvlights.com have tons of wiring kits if you ever do need a replacement..
Old Mar 28, 2011
bad_boy19914's Avatar
bad_boy19914 is an unknown quantity at this point
Re: civic headlight wiring
hey have you found the problem??. i have the same problem
Old Oct 4, 2016
docjiraiya's Avatar
docjiraiya is an unknown quantity at this point
Greeting all. I have a question? just installed some Spec D projector headlights.
they have a pair of bulbs for low and a pair for high. I want to know if there is a way to wire them that the dims stay on when i flip on the brights
Old Oct 4, 2016
bust out your electrical skills and install a diode between the low and high beam ground wires (the H4 harness on our cars are ground switching). theres a schematic somewhere on these forums.
edit: here's the link https://www.civicforums.com/forums/2...e-lowbeam.html
Either that or buy a relay harness designed for aftermarket HID installs. I have one for my HID setup that I got from theretrofitsource.com that keeps low beams on when you activate your high beams. Costs something like $35 plus shipping.
edit 2: here's the relay harmess I have
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
usajags84
15
Aug 19, 2015 03:12 AM
shaejb15
Apr 26, 2015 07:44 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
NukeSilo
Nov 4, 2001 09:37 PM
