Fog Lights with Automatic
Old Jan 23, 2006
Thrasher086's Avatar
Thrasher086 is an unknown quantity at this point
I have a Honda Civic 2001 4 Door Automatic. I just bought one of those 30 dollar kits off of ebay. The fogs are the 2001 model with the switch. I wired everything up with my friend. We used the Honda intrustions to help us out. Then we seemed to run into a problem. The intructions around number 45 or so, show 3 plugs going into the fuse box. I only have 2 that can fit into it! Is there anything I can do to get these lights on and use the switch? We got so far and this is all I need.
Old Jan 23, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
pics?
Old Jan 24, 2006
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
sections 2 & 3 of the pic are where you're supposed to connect the wires.
Old Jan 24, 2006
What is section one for? I have an automatic and heard that I need to plug in 3 wires. Can I just do 2?
Old Jan 24, 2006
FALKEN's Avatar
Civicforums Junkie
moved
Old Jan 24, 2006
Xenin's Avatar
i have an auto as well, you dont need it for ebay fogs.
Old Jan 25, 2006
What places did you use to ground. I cant seem to get that lights on and just wanted to make sure I have good groundage.
Old Jan 25, 2006
you can use any stock ground point, or make your own. pretty much anywhere on the chassis that has metal.
Old Jan 25, 2006
I have everything plugged in right and I still cant seem to get them on. I cant figure it out. The grounding seems good. What does this plug do that I boxed in red? I can't seem to find where it plugs in.
Old Jan 26, 2006
Xenin's Avatar
that goes into section 2 of my pic. for a ground on the interior harness theres a screw bolted onto the frame near the fuse box on your right that has other wires on it as a ground. use that.
Old Jan 26, 2006
Ok Thanks, I'll do that. I am starting to think that the switch may be broken which is causing the lights not to go on.
Exterior
Nov 28, 2025 05:23 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
