Foglight switch still lights up with fuse pulled?
Old Jan 15, 2006
dalaw's Avatar
Bone Stock!
My OEM style foglights havent been working for a while now. Today, I finally found the fuse location to the foglights, and turns out that it was melted, but not blown. Why is that? The melted fuse is a 30A, but according to handaaccessories, it should be a 20A. . With the fuse gone, I turned on the switch, the foglights didnt come on, of course, but the switch inidcator light still comes on! Why is that? Also, the shop that installed my foglights soldered 3 wires onto the switch. I tested the wires with a multimeter, and all of them have a connection, even with the switch and parking lights in the OFF position, and fuse pulled out! Do I have a short somewhere? Everything else seems to be ok (wires under the hood, 55W bulbs, power relay). Help!
Old Jan 16, 2006
AlienX's Avatar
AlienX will become famous soon enough
relay might be dead... did u test it ?
the switch still lights up because it is probebly powered though a diffrent connection.
have u tried to isolate any of the connections by connecting them directly ?
start from the fogs to a 12v source, then move the switch to a 12v, g, and output and test to see if the output gives power, and last, test the relay. If every works out, start checking if you have connectivity between your switch to the relay, relay and fuses.. ect... you might have burned the wire somewhere.
Old Jan 19, 2006
dalaw's Avatar
Bone Stock!
thanks for the advice man, i ll check if the relay and fuse are bad.
Old Jan 27, 2006
ClutchEm2's Avatar
ClutchEm2 is an unknown quantity at this point
I had the same exact problem and fixed it tonight. My fuse was melted along with the little fuse box. Cleaned all of it up and rewired it. I put a new fuse in and everything was good to go. I had a 30a as well but now use a 20a.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
werdnahall
May 17, 2015 11:37 AM
smmahan
Apr 15, 2015 08:17 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Sarsura507
Feb 5, 2008 09:54 AM
