Trunk/Gas LEVER stuck...
Old Nov 28, 2005
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
Due to crime I usually use my key to lock the trunk lever so that thieves can't open it from inside of my car. Well not too long ago I brought my car in for alignment and tire service and I notice a few days later the problem:
Even unlocked the lever (lift up for trunk and push down for gas) seemed stiff. I could open my trunk, but if I force it to go up all the way. I push down and open the gas door, but it has to be all the way down.
I don't know if it was the service guys that tried to open my trunk or not, but that's when I noticed the problem arise.
Question: How can I take apart that piece apart and mess around with it? I think it's the cable that is no longer attached. Thanks ahead of time.
Old Nov 28, 2005
CraigW's Avatar
The cover slides/pops off for some access. You can then get a socket on the bolt to loosen the assembly.
Old Nov 28, 2005
Jrfish007's Avatar
I had the same problem... ended up I had some ice and crap in there and next time it got warm it was fine. Only did it once, which was wierd.
Old Nov 28, 2005
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
mine has been stiff lately, the lever doesn't go back down on its own when i pull it up
Old Nov 28, 2005
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
u guys have a rear tower bar cause when i installed mine the cable for the trunk/gas was acting the same way and i noticed the bar was laying right ontop of it. mayb that helps?
Old Nov 28, 2005
sKwiD's Avatar
I Queef > You
Yeah, it was right after I installed that and the lower tie bar... I didn't see any cables though... How did you fix it?
Old Nov 28, 2005
crazyasian's Avatar
i just unbolted the bar where it was laying ontop of the cable and just had the cable go over the bar.
NightHawk04
Brakes DIY
Oct 12, 2017 09:25 PM
Sep 3, 2015 07:01 PM
jdrolltide
Sep 1, 2015 06:54 PM
WaryDriver
Aug 22, 2015 06:50 PM
muttleytm
Jul 11, 2015 06:00 PM
