GC coilovers wont lower in front.
Old Oct 23, 2005
GeminiZ's Avatar
GeminiZ is an unknown quantity at this point
well i got the ground control coilovers installed on my 04' civic from this site sportcompactonly and when it was finished installed the back was dropped nicely. but the front is still at stock height. i tried screwing the adjustables up and down but the only thing that happened was the front end got even higher... even when i put the adjustable on the lowest thread, it still doesnt look low at all. there is like a 5 finger gap or larger between the tire and the fender? what is happening here. i need help thanks!
Old Oct 23, 2005
gangrel138's Avatar
gangrel138 is an unknown quantity at this point
Hmm. Not sure. You took it all the way down as in towards the ground on the threading? Do you have some pics so we can see exactly what might be wrong? I don't have experience with GC yet. Still waiting on my friend's GC coilovers to show up for his Talon.
Old Oct 23, 2005
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
in order to lower the car, you have to thread the adjusters UP compressing the spring. This will lower the car.
Another reason sleeved coilovers suck, because you loose shock travel when you lower the ride height.
Old Oct 23, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
You do lose ride travel, but if you size the springs correctly, there's more than enough. And to lower the car you thread them down.
Post a picture of them installed. if you have as much room as you say, I'm guessing you didn't install them right.
Old Oct 23, 2005
Ryan2005's Avatar
Ryan2005 is an unknown quantity at this point
i have gc on my 05 you have to thread down to lower it
Old Oct 23, 2005
fuledya's Avatar
Super Member
yea, you thread them up, i don't know what i was thinking
Old Oct 23, 2005
Al Gore FTW's Avatar
jdmtytedoridori
im guessing they are installed wrong...i think i know what he did wrong, i just dont know how to say it.
Old Oct 23, 2005
GeminiZ's Avatar
umm. Ryan2005 do u happen to have a picture of your front gc's installed i could look at.. and this was a professional shop that installed it... i didnt even touch it.. i'll try to get some pics up
Old Oct 24, 2005
GeminiZ's Avatar
alright i took this with my phone... this is the front right GC installed
when this is off the jack this is about a 7finger wheel gap..
Old Oct 24, 2005
ferio's Avatar
ferio is an unknown quantity at this point
mine does not look like that. my sleeves are over the strut(my shocks are in my sleeves ). it should look like this
Old Oct 24, 2005
bhoy's Avatar
bhoy is an unknown quantity at this point
thats wrong check mine...i drop it 4"....and 2" from the ground
Old Oct 24, 2005
bhoy's Avatar
heres mine
Name:	new pic (3).jpg
ID:	61442   Click image for larger version
ID:	61443   Click image for larger version
Old Oct 24, 2005
bhoy's Avatar
here u go......
Old Oct 24, 2005
GeminiZ's Avatar
so my problem is that the sleeves arent not wide enough to fit around the btm portion of the strut? does that mean Ground Control did not send me the right sleeves or do i have to buy a smaller strut? are your struts stock or aftermarket?
bhoy what am i supposed to cut when i take that strut seat off?
Old Oct 24, 2005
gangrel138's Avatar
I would like to quote the GC advertisement...
A) some shocks / struts require grinding / machining to fit coil-over hardware
If I were you I would take the car back to the shop who installed it and tell them to do it right. Make a printout of this page along with the supplied pictures of the sleeve in the correct position.
Old Oct 24, 2005
ferio's Avatar
you dont have to cut the seats(though it would be easier to adjust by cutting part of the seat) i dunno why it does not fit. maybe they sent you the wrong sleeves?
Old Oct 24, 2005
Jap-Euro Fusion
They put the fronts on the rear and the rears on the front. Get your money back, take it somewhere where the people working on it know what theyre doing
Old Oct 24, 2005
acidbaby's Avatar
The Beez Kneez
you are right! can we see a pic of the back?
Old Oct 24, 2005
gangrel138's Avatar
Boilermaker is probably right. Ockham's razor strikes again.
Old Oct 24, 2005
Jap-Euro Fusion
Boilermaker IS right. The short collars go in the rear. The other dead give away is the tapered coil. The front springs are straight. The rears taper in because of the smaller seat diameter in the rear. So like I said, idiots did the work for you, get your money back, take it to your own driveway and fix it. If not, make sure they fix their **** up for free (and a free alignment for the inconvience).
Old Oct 24, 2005
ferio's Avatar
^^lol! you beat me to it. i thought about that when i was in class this afternoon! hahahah! yup boilermaker is right.
Tedverseti
Apr 23, 2020 01:45 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
Tedverseti
Sep 29, 2015 05:41 PM
