GC coilovers wont lower in front.
well i got the ground control coilovers installed on my 04' civic from this site sportcompactonly and when it was finished installed the back was dropped nicely. but the front is still at stock height. i tried screwing the adjustables up and down but the only thing that happened was the front end got even higher... even when i put the adjustable on the lowest thread, it still doesnt look low at all. there is like a 5 finger gap or larger between the tire and the fender? what is happening here. i need help thanks!
Hmm. Not sure. You took it all the way down as in towards the ground on the threading? Do you have some pics so we can see exactly what might be wrong? I don't have experience with GC yet. Still waiting on my friend's GC coilovers to show up for his Talon.
in order to lower the car, you have to thread the adjusters UP compressing the spring. This will lower the car.
Another reason sleeved coilovers suck, because you loose shock travel when you lower the ride height.
Post a picture of them installed. if you have as much room as you say, I'm guessing you didn't install them right.
umm. Ryan2005 do u happen to have a picture of your front gc's installed i could look at.. and this was a professional shop that installed it... i didnt even touch it.. i'll try to get some pics up
alright i took this with my phone... this is the front right GC installed
when this is off the jack this is about a 7finger wheel gap..
Originally Posted by ferio
mine does not look like that. my sleeves are over the strut(my shocks are in my sleeves
). it should look like this
). it should look like thisbhoy what am i supposed to cut when i take that strut seat off?
I would like to quote the GC advertisement...
A) some shocks / struts require grinding / machining to fit coil-over hardware
If I were you I would take the car back to the shop who installed it and tell them to do it right. Make a printout of this page along with the supplied pictures of the sleeve in the correct position.
They put the fronts on the rear and the rears on the front. Get your money back, take it somewhere where the people working on it know what theyre doing
The Beez Kneez
Originally Posted by gangrel138
Boilermaker is probably right. Ockham's razor strikes again.
jackoncruzpr
Sep 29, 2015 07:59 PM
