head unit keeps blowing fuses
Old Jul 7, 2005
invrtdsa1nt's Avatar
invrtdsa1nt has a little shameless behaviour in the past
Whenever i connect the constant (yellow) wire on my hu it blows the backup fuse. So I figured that wire was shorting out somewhere so i connected it to the constant that connects to the hazard button, which goes to the hazard/turn signal fuse under the hood, and that gets blown. So that leaves me to think its a problem inside my hu. Has anyone had this type of problem? Thanks.
Old Jul 7, 2005
pr0vidence's Avatar
pr0vidence is an unknown quantity at this point
Either you got a cooked head unit or your wiring harness has a short somewhere. That would be my best guess. If the HU is brand new, get it replaced.
Old Jul 7, 2005
CraigW's Avatar
Most mfgrs offer a replacement type warranty, (time length varies) You send yours to them and they send you a "repaired" unit and then repair yours and re-use it for the same purpose.
Do you own multimeter or have any way to check resistance ??
Old Jul 7, 2005
na i dont have one of those but one can be acquired easily. so should i check the resistance of the ground?
Old Jul 7, 2005
MegaHurtz's Avatar
does your stock head unit still work?
Old Jul 7, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
test the deck grab a length of wire put a 10 amp fuse in it. now twist the yellow and red wire together with the length of wire that has the fuse. ground the black wire on the deck and put the wire with the fuse in it to the bat. if it blows then you have a bad deck. if it doesnt then haha way harder to fix that.
Old Jul 7, 2005
MegaHurtz's Avatar
i dont see why a multimeter would be useful in this case or why resistance would be an issue... problem most likely lies with his wiring or the head unit that he is putting in
Old Jul 7, 2005
MegaHurtz's Avatar
well all he has to do to check the deck is plug the stock head unit back in, if it works he can deduce that the problem is either the harness or the head unit.... if he is certain that the harness is correct, it will have to be the head unit
Old Jul 7, 2005
CraigW's Avatar
I was suggesting to check the resistance of the memory lead from the problem deck to ground to see if that is the source of the short.
Old Jul 7, 2005
nick95673's Avatar
from my experience. i would try megahurtz's idea first to just plug in oem deck and see if it works. then my experience tells me that most ppl who have problems attempted to hardwire something in the past or didnt feel like buying a 15 dollar metra part and messed somethin up. then 3rd bring it to someone who knows what they are doing or go get a new deck.
Old Jul 7, 2005
MegaHurtz's Avatar
how would measuring resistance prove that that is the short?
Old Jul 7, 2005
CraigW's Avatar
Short circuit = 0 Ohms to ground from memory lead / Granted this may not work on every single situation but a good simple method for tracing the short for me would be an Ohm meter.
Another good method is to place a small wattage bulb in place of the fuse that is blowing, as long as the short is present bulb will glow at full brightness. Remove the short and bulb will go out complete or dim.
Old Jul 7, 2005
well, the whole reason i mentioned that the fuse blew when i tried both the back up and hazard light wires is to kinda show that it's probably the hu. if i wire the hu to the hazard lights and the fuse blows, replace the fuse and hazards work fine, obviously its not the wiring harness. But does anyone know if this is fixable? I got my hu off ebay, I dont know where i could take it to get it fixed. and im not exactly the type of guy to pay someone to fix something that cant be fixed by myself.
4 banger
Jun 5, 2015 01:44 AM
mugenca
Apr 16, 2015 12:15 AM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
