What is the best oil filter wrench/tool out there?
So I was changing my oil today and I had one hell of a time getting the filter off. At first I had used the regular filter wrench that connects onto a ratchet, but the filter wrench just turned on the filter, so that didnt work. Then I tried one of those tools that you can adjust, it has a leather belt on it, but that didnt work. Then I tried a adjustable wrench, and that didnt work. I ended up having a tech get it off just barely with channellocks, since they barely fit up in there.
I am wondering, what is everyone using to get this off or what would you recommend so it wont be a big deal each time.
Buy some of those yellow rubber kitchen gloves, they will grip the filter good enough to get it off without a wrench, unless of course someone over tighten to filter way to much. i like my filter tight, but not to tight, the gloves still work.
You know, I had this problem yesterday... I epoxied a cap type wrench to the filter and spun it off. Then put the new one on at a point where I knew I could get it off. Damn dealer *******s cranking **** on, I can't stand it.
All my filter wrenches are too big for my filter cuz they are made for our trucks and machines. So i just use a pair of channelocks to get it off and then hand tighten it.
only thing I dont understand about the filters is that it says once the gasket contacts the base, tighten it 1.1/4 turn from there. I dont like that because when I put it on, I go untill it is tight, not too tight, but tight.
I have one and it doesnt work for ****.
Originally Posted by Civic_RedLine
um get the tool from honda oem, they are like 5 bucsk
i use one of these....
the grip wrench
i got it for free and i thought it was the biggest piece of **** tool ever, until i tried it with my oil filter, works like a charm. you can get them for like 5 dollars at home depot.
the grip wrench
Originally Posted by ex_03
autozone sells the the cupwrench for our filters for like 6.00 works great, but yea it should only be hand tight. I have had to use it to get my filter off a few times worth it to me.
Originally Posted by dru106
just a reuglar oil filter wrench is fine! Thats what i used and never had a problem.... I hate those one wrench that goes over the ratchet
Originally Posted by streetglower
thats the one that doesnt work for me. Maybe it is just because I have the fram filters on there with the sure grip stuff on the end.
ThE CoRRupToR
what is the regular filter wrench, I always thought it was the one that hooked to a ratchet.
Oops!! ur right i mean pliers......
The Declaration of Independence was written on marijuna paper
I used to use K&N filters which had a 1" sized wannabe nut at the end so you can use a ratchet to get it off. I have pureone on right now, when I go to take that one off it's going to be a biatch.
mistermenphis22
Jul 13, 2015 04:43 PM
1khilari
Jul 9, 2015 08:12 PM
CivicsClass101
Jul 9, 2015 11:14 AM
