60k - what should be done?
In 10k I will be at 60k. I want to prepare for what I am going to have to do
Flush radiator and refill
Flush brake fluid - replace with ATE Superblue
Change MTF - replace with Honda MTF
Change rear pads - replace with Honda pads
Change clutch fluid - what should I replace it with??
Change power steering fluid - change to redline??
Oil changes are on a different schedule so what else do you suggest? Belts are good to 100k right? Plugs were changed at 20k with Iridium. What else? S2kman??
If your manual says to change those fluids, then you should change them. Brake pads don't need to be changed unless they are actually low.
As for what fluids, honestly, your civic manual will tell you exactly what to use. There are specifications set by the API for example and other such agencies, and honda will specify which fluids to use.
bah, i lost my manual! haha
I was thinking about upgrading powersteering and clutch fluids if it won't hurt the car, because of autox. Rear shoes need to be changed. Front pads have plenty of time to go. Have to factor in the abuse from autox, so I want fluids to be good. I know MTF should be Honda.
-Yes
-Good choice
- Actually, use Redline MTF. Your transmission will shift better and last longer.
- Only if needed.
-DOT 4 brake fluid, make sure you flush and bleed it properly
-Honda power steering fluid is just fine
- Stick with what you've been doing, around 3000 miles
- Look at them, if they look worn or are starting to fray, replace them. Gates belts work great as well as Honda belts
-NGK's are cheaper and work just as well. Just use NGK next time
What else?
- Tires, obviously. Alignment. Fuel filter if it hasn't been done already, check your intake air filter (clean it if it;s a K&N)
You should be good to go after that.
-Yes
-Good choice
- Only if needed.
What else?
-Yes
-Good choice
- Only if needed.
What else?
-Yes
-Good choice
- Only if needed.
What else?
I was always told not to use redline in our trannies because the sychros will go bad...?
transmission fluid doesn't need to be changed till 120k miles (according to chiltons). but since you autox and drive hard, i suppose it would be nice to give a change.
check belts and hoses for wear.
Ok, well my two questions are
What power steering fluid should I use? Honda or Redline...
What MTF should I use? Honda or Redline...
I have been told conflicting messages. Thank you.
Destinationunknown- The only reason I don't say to use ATE superblue in the clutch is that it is much more expensive than DOT4, and you have to use a decent amount to completely flush out the original fluid and bleed. The clutch line is not a line that you have to worry about boiling the fluid like the brakes (unless you ride the clutch like no other). Super Blue will work, but it's not necessary. But if you have enough left over- by all means use it.
so use whichever you want. if you have not heard from anyone who actually USES redline tranny fluid then stick with honda.
Escaped Convict
if u lost ur manual. get the info at honda's owner link.
https://www.ahm-ownerlink.com/login.asp
i'm gonna go with sticking with honda fluid too (although some of them are just another with honda name on it) for ur civic. they're not too overpriced and are easier to obtain.
you know, your driving condition and driving habits factors into your 60k matainenance/tune up too.
Not for me, I work about 5 miles from Summit Auto Racing
If you've been autox, check all you suspension parts. If you can try to get it up on a rack and look carefully at the bushings and make sure nothing looks like it's starting to bend or crack (tie rods, control arms, blah blah blah). But I would do that more often then 60k if you're autox
Thanks everyone for your help!!!
60,000 mi/96,000 km/3 yrs Scheduled Maintenance
Replace engine oil.
Rotate tires (follow pattern on page 241 of your owner's manual).
Replace engine oil filter.
Inspect front and rear brakes.
Check parking brake adjustment.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connections.
#Inspect exhaust system.
#Inspect fuel lines and connections.
#: See information on maintenance and emissions warranty, last column, page 195 of your owner's manual.
Inspect and adjust drive belts.
Replace air conditioning filter*3.
*3: See air conditioning filter on page 235 of your owner's manual for replacement information under special driving conditions.
Replace air cleaner element every 30,000 mi/48,000 km (independent of time).
Replace transmission fluid (CVT)*2.
*2: Replace at 60,000 mi (96,000 km) or 36 months, then every 40,000 mi (64,000 km) or 24 months.
Check engine oil and coolant at each fuel stop.
Check and adjust valve clearance, cold engine, if noisy.
Oh damn - valve clearance. i hate doing that ****.
Replace engine oil.
My car has almost 45,000 miles. Just today I had oil, anti freeze, brake fluid, filter, rear rum adjust, e-brake adjust, enigine valves adjusted, and trottle body coolant bypass. My friend said the valves were loose. Honda sent me a free $100 gift certificate, so I used Mobil 1 oil, Honda anti freeze and brake fluid, ilter and it was done on the dealers BP brake machine. Cars running like brand new.
-Yes
-Good choice
- Only if needed.
What else?
-Yes
-Good choice
- Only if needed.
What else?
go to www.honda.com click on the 'ownerlink' link and register. it will give you all the info on your car and what's due at what time!!
xeroid
Aug 31, 2015 10:53 PM
lapchern
32
Jun 20, 2006 04:44 PM
