Mind boggling quotes from two honda dealers for 60k service...
so i'm approaching 60k soon and I call two local dealers to get a quote on their 60k packages.
Goudy Honda
60k service (includes transmission oil replacement) - $189.95
Transmission oil replacement only - $40
Spirit (formerly Nelson) Honda
60k service (does NOT include transmission oil replacement) - $369.95
Transmission oil replacement only - $70
What's up with the huge gap? Can anyone vouce for these two dealerships' service depts? It seem slike a no brainer to go with goudy.
To me it seems like the main thing to look at when hitting 60k is the transmission oil. I can do the pollen and air filter myself. Anything requiring me to go under my car i go somewhere to get it done.
Goudy Honda
You just need to do transmission and oil change. Total cost, $30-40 and maybe an hr of your time. Thats only if you get the expensive oil, but i do recommend the honda atf though.
Originally Posted by civic4dizoor
your join date : DEC 2001 ????? ur oil\tranny fluids , brakes , sparkplugs if u havent already done it .
motor oil was changed recently at a local shop where i bring my own oil for cheap labor.
pollen filter i will do myself.
transmission fluid i'm probably going to goudy honda to pay $40.
brake fluids i will take it somewhere as well.
am i missing anything else?
i've never jacked up a car (nor do i have one except the wee little one that comes with the car) before so i'm a little nervous going under the car to do something like this.
i've done other things like replace my power door lock actuator and stuff like that tho! actually
Spark Plugs: 110k or 6yrs
Air Filter: 6k
ATF: 100k or 5yrs
Oil: 3k or 3-5mths (depending how much u drive)
Pads: every 6 mths
Brake & PS fluid are the only ones i would recommend going to the dealer, their work is insured, plus dealer + brake + steering = safety & peace of mind (usually)
Air Filter: 6k
ATF: 100k or 5yrs
Pads: every 6 mths
A big, hairy Kentucky boy
Originally Posted by orion_squall
You will need a certified mech only when something actaully breaks down.
Or when you and your mechwarrior buddies get surrounded.
Originally Posted by blackdragon
actually
Air Filter: 6k
ATF: 100k or 5yrs
Pads: every 6 mths
Air Filter: 6k
ATF: 100k or 5yrs
Pads: every 6 mths
I change oil every 10,000 miles using synthetic.
PWIT
actually
Air Filter: 6k
ATF: 100k or 5yrs
Pads: every 6 mths
Air Filter: 6k
ATF: 100k or 5yrs
Pads: every 6 mths
Get the PMC Laser goin!
Originally Posted by cleancivic 05
man u have to learn how to work on ur own car
i agree. i do try to work on my own car... hey i installed a K&N air filter :-).
i just wish i had a buddy who knew how to walk me through the first time doing these kind of things.
As for the person who says ATF every 100k... general consensus on the forums seems to be either 60k(as noted by manual under 'sever') or 30k...right?
offtopic... is the factory jack more than enough to help u lift the car and do an oil change?
< My future wife.
civics dont even have tranny fluid filters just drain and fill! 60k services are mostly inspections. You either inspect yourself or most oil change facilities do some of the inspections for you. You can pay dealerships to do an annual inspection for 75-100$ which is like a 128 point thorough inspection, and is CHEAPER THAN THE 300$ for a 60k service you dont need. Other than fluids I personnally plan to have everything done at 95-100k. Including spark plugs, timing belt, water pump,any filters that i havent already done, coolant flush, fuel system cleaning, valve adjust, maybe a new battery.I have 68k and have changed oil every 3-5 k and swapped tranny fluid twice.I bought brake fluid to change soon. I stillhave original brake pads and they are just under a quarter inch(1/8 inch= replace). brake pads every 6 months LOL thats ridiculous!
When doing the trans fluid...It's better to flush it all out...because when you just drain and fill.. you're only draining about 3qt of fluid out of the pan...the rest of the trans fluid is in the transmission...You don't replace all the fluid unless you do a transmission fluid flush. Got my done at the dealer for 100 bucks. Check your fluid after they're done because mine was low...I don't trust anyone
At least get yourself a 2 ton floorjack. They're only like $20. Sometimes they come with jackstands for like $30.
Originally Posted by digitaldemigod
I would never, ever, ever, ever, EVER get under a car with a flimsy little jack like that.
would i need 2 sets of these things?
You need one floor jack, you jack up the one side, then stick a jack stand under the car. Lower the jack, bring it to the other side and repeat.
2 jack stands
one jack
2 jack stands
one jack
2 jack stands
one jack
hi
As a car illiterate myself, I would still suggest you doing things like oil change, ATF change. THey are can done by general public with no skill.
Break fluid change, coolant change, rotors, shoes replacement are harder and if you are really scared of liability then have those done by professionals.
By the way, members, do we have any collant DIY somewhere on this website?
thanks
2 jack stands
one jack
2 jack stands
one jack
Hi,
thanks
thanks
Your first atf change you want to do at 30k. The reason for that is because all the metal shards that came from your engine when you were breaking it in is still flowing around your tranny. When i did mine at 30k, my tranny fluid was orange and had bunch of metal shards. The mileage can vary depending on your area and drive style. Change the atf basically when the fluid isn't red anymore, especially on the autos.
oil you don't have to do at 3k. This isn't your grandpa's engine and d17 isn't a performance one. You can just do it at 5k unless you really beat on your car. Causal driving or highway driving you can do 5-7500 miles before an oil change.
Just spend $30 on real jack stands and $20 on a wrench set and you can use them everytime you work on your car. Doing a fluid change isn't difficult, just time consuming, especially your first time.
Might as well ask this question, since jack stands were brought up.
I've jacked up the car before and used jack stands, but ive always run into a problem when placing the jack stands under the car. I use the jack points(whatever they're called) to jack up the car, but then when I'm putting the jack stands do I use the same jack point or can I put them somewhere else? because theres never enough room for the jack and jack stand to fit on those jack points at the same time (when im lowering the car with the jack onto the jack stand).
Originally Posted by ajhdragon
the gap in prices are proably jsut because of the locations the dealerships are in. the one that sells to higher clientel proably charges more.
