Mind boggling quotes from two honda dealers for 60k service...
#31
Originally Posted by civic_04
Might as well ask this question, since jack stands were brought up.
I've jacked up the car before and used jack stands, but ive always run into a problem when placing the jack stands under the car. I use the jack points(whatever they're called) to jack up the car, but then when I'm putting the jack stands do I use the same jack point or can I put them somewhere else? because theres never enough room for the jack and jack stand to fit on those jack points at the same time (when im lowering the car with the jack onto the jack stand).
This way you can put the jack stands in the proper locations at the same time.
#32
Rep Power: 359 yea im at 30k, and i will be changing my atf fluid when i get home, pollen filters , or the ones in the cabin, plus oil change tire rotation, then i will check the other fluids and see if there is anything else i need to do, but i think that is the main stuff right?
Xuhme
21
08-07-2023 03:40 PM
CarStuff
12-06-2020 12:52 PM
