Sound when Lights Left On Doesn't Work
Old Apr 18, 2005
Aznnp77's Avatar
All Show No Go Sedan
Aznnp77 will become famous soon enoughAznnp77 will become famous soon enough
Hey guys, it's been going on for about a year or two now, but I never got around to fixing it. The beeping noise that is suppose to come on when u turn off your car and have your lights on doesn't work anymore. I dealt with it for a while, but I've done it twice in the past 2 weeks, and had to have a friend come by to jumpstart me. Is there like a fuse somewhere that I blew out? I checked the ECU/Fuse box and I don't think there is a fuse for something like that. Hopefully this doesn't require me to dig too deep into the car, cuz I'm not good with technical stuff.
Wow, sorry to revive this topic from the dead, but I have finally gotten around to wanting to fix this problem. I went to my front door to try and find those stops, but I wasn't sure which one it was. If you guys could be so kind as to tell me which one it is, and possibly how to install it, I would appreciate it. Theres those screws under the top one, I don't wanna touch em unless I have to. I realize I never turn my lights on until it gets really dark cuz I'm afraid of forgetting and leaving them on.
http://www.hondaautomotiveparts.com/...NT+DOOR+PANELS
I think it's number 16 or 20?
Old Apr 19, 2005
Aznnp77's Avatar
come on guys im sure my car isn't the only lemon around here. its bad enough that my car got 24 mpg stock.
Old Apr 19, 2005
CraigW's Avatar
Is anything else not working ??, Does the "key in" buzzer work ??, Have you looked at all the fuses ??
Old Apr 19, 2005
skipbarber's Avatar
buzzer is in the gauge cluster isnt it? but i bet there is a fuse for it.
Old Apr 19, 2005
BOOSTLESSD17's Avatar
cant boost cuz it'll wreck the name
BOOSTLESSD17 is an unknown quantity at this point
It will probably the door switch right under where the door latches. They break easy. It's warranty. When I worked at honda we replaced tons of them.
Old Apr 19, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
yup, it's the driver side door switch, mine had the same problem, bet ur overhead light doesn't turn on when you open ur dorr either?
Old Apr 19, 2005
I wish mine stopped working.
Old Apr 19, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
its drivers side door switch, my drivers side broke a week ago my passenger side broke half a week ago. The parts $12 cdn from honda/acura
Old Apr 24, 2005
Aznnp77's Avatar
Wow, sorry for the late reply guys but I've been busy with work and school. Sounds like a pretty complicated process to me, and I've never taken anything like that off before. I don't think my light comes on when I open my door? Is it suppose to? I don't think I ever noticed.
P.S. My car is 4 years old and at 63,000 miles, so it is no longer warranty issue.
Old Apr 24, 2005
booba5185's Avatar
it's not hard at all, there is a black rubber switch on the frame of the driver side door, it's thebutton that tells the car that the door is open or closed, the wire either fell off or it's stuck, there's a rubber flap on the buttom that swings down and there is a phillips screw, when u unscrew it u will be able to pull out the switch, there will only be 1 wire connected to the switch, if the switch is broke, take it to the dealer and say "i need this" then they will give you a new one, plug it in, screw it back on, and tada, it's fixxed
Old Apr 25, 2005
yeah its real easy to do, if your really not that confident in doing it, go get an oil change and have a mechanic pop it in, its so simple I doubt they'll charge you
slynger
18
May 8, 2015 06:06 PM
Dorval Andre
May 1, 2015 09:37 AM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
darwin-t
Apr 18, 2015 09:29 PM
GhettoCivic
Nov 12, 2001 03:15 PM
