Re-Wiring Some Stuff.....HELP
Old Apr 14, 2005
steak84ss's Avatar
steak84ss will become famous soon enoughsteak84ss will become famous soon enough
Just a couple of questions. I'm doing some re-wiring behind the head unit and installing my amps. Now, I've done this on a number of cars but do you think I could remember...? Do I hook up the remote wires for my amps to the power antenna wire? Do we even have a power antenna wire?
I could REALLY use the color code for the stereo harness as well. Thanks
-Steak
PS....it's a 2003 Vic EX Sedan
Old Apr 14, 2005
steak84ss's Avatar
Well, I just realized that under the Navigation section of this site, there is a wiring diagram section..........yeah I suck
But what do I hook the remotes to?
Old Apr 14, 2005
CraigW's Avatar
It should be a blue/whte stripe wire from headunit. It should labeled remote or similar.
Blue = power antenna
Old Apr 14, 2005
steak84ss's Avatar
Originally Posted by CraigW
It should be a blue wire from headunit. It should labeled remote or similar.
Thanks. I'll go outside and check now.
Old Apr 14, 2005
steak84ss's Avatar
OK. Coming off of the Clarion wiring harness, there are 3 wires NOT being used.
Brown
Blue
Blue with White
Which one do I use for the Remote lines?
Old Apr 14, 2005
circa3182's Avatar
circa3182 is an unknown quantity at this point
You should use the Blue one, however I believe that the blue with white stripe will work as well. Have fun
Old Apr 14, 2005
steak84ss's Avatar
YOU RULE!! Thanks. The stereo should be running within the hour now.
Old Apr 14, 2005
05reverb's Avatar
05reverb is an unknown quantity at this point
yeah use the blue wire, the blue with white stripe is for power antenas
Old Apr 15, 2005
steak84ss's Avatar
Actually, I tried the blue wire and it didn't work. The blue/white for the antenna actually makes more sense. When the radio is turned on, it sends a signal out to turn something on. Even if my explaination sucks and is wrong, it worked.....LOL. Thanks again.
-Steak
Old Apr 15, 2005
SlimmKidd's Avatar
SlimmKidd is an unknown quantity at this point
so where does the power ant wire go help.........I have limited radio capabilites!!!!!
Old Apr 15, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
always use the blue as an accessory wire. always
Old Apr 15, 2005
silverem2's Avatar
this is why I paid the store to hook up my dvd unit in the car
Old Apr 15, 2005
steak84ss's Avatar
Are you talking blue from the stock wiring harness or blue from the aftermarket wiring harness? The blue from the headunit did nothing but the blue/white gave me my signal I needed for the remote lines.
Old Apr 15, 2005
04civicvp's Avatar
04civicvp is an unknown quantity at this point
From aftermarket headunits, the blue wire is for power antenna and the blue with white stripe is for amp turn-on. If the headunit has both of these wires, using the blue wire for your amp may result in the amp turning off when using the CD or AUX. Some radios are setup to only power the antenna wire when the tuner is selected.
Old Apr 16, 2005
swkfilms's Avatar
swkfilms is an unknown quantity at this point
im confused is this correct?
BLUE WIRE - not used unless you have a power antenna
BLUE W/ WHITE STRIPE - To be used as remote wire when installing amps
is this correct? anyone disagree? im just trying to learn something that i didnt know. On my amp i ran the remote into the fuse box that is under our steering wheel by our feet and ran it right to one of the fuses in there. I think it was the radio fuse but any one of them will do it. It just tells the amp to turn on when the car turns on and that fuse gets power.
Old Apr 16, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
No, in our cars you have to hook up the power antenna wire. Even though we don't have a power antenna, it still needs to be hooked up to maximize the radio reception.
Old Apr 16, 2005
steak84ss's Avatar
Not sure what that's all about but there's nothing to hook it up to and my reception is perfectly fine. Yes you have to use the blue with white off the aftermarket headunit for your amp remote lines. I did this shortly after I started this thread. I originally hooked up the blue for the remotes and it did nothing.
-Steak
Old Apr 16, 2005
Octane Joe's Avatar
just an Idea... READ THE MANUAL!!!! the manual ALWASY has the wires labled, if not the wires them selfs are labled, and if you have a harness adapter (required for aftermarket hu) the wires are labled on the harness AND on the back of the plastic it came in.... HU instilation is not rocket science, if you can read, you can do it! I cant stand when pplz pay best buy or circut city or any other rip off artist 60+ $ for a simple instalation!!!!!!!!!!!!!!!!!
sorry... im stuck working 12 hr shift and am missing a civic meet as speak... and I am dealing w/ people that have a lower IQ than my cat
Old Apr 16, 2005
steak84ss's Avatar
You find me an aftermarket headunit manual that shows me the color code on their harness and you might actually have a point but with all the headunits I've ever had, they NEVER give you color coding.
Old Apr 16, 2005
swkfilms's Avatar
yeah i agree steak, i was just trying to learn something either way. thanks for the input guys!
Old Apr 17, 2005
-Steak
If you have issues with reception, 99% of the time, this is the problem, hooking up the power antenna wire, gurantee you. Search through the forums for all the threads about it, 99% of the time, that fixes the reception issue they were having. True, the fact that the antenna is in the back window contributes majorly to reception issues, and tinting makes it worse. But, most aftermarket reception problem comes from not hooking up the power antenna.
Old Apr 17, 2005
04civicvp's Avatar
Hey, that's my lively hood you are talking about. If it wasn't for those clueless people that actually need me to install there stereos and amps, I would be out of a job.
Old Apr 17, 2005
SlimmKidd's Avatar
So like I said where dose the solid blue wire on the after market wiring harness go. the blue wire marked power antenna. Does it get hooked up the remote lead on the aftermarket deck cause it is BLUE with a WHITE stripe. Then does that get hooked up to the remote lead from the amp???
Old Apr 19, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
yea Im luaghing about this one, They keep saying to hook it up, to what? the wire on the cars harness goes nowhere? LOL yep, true experts here!!!!
Old Apr 19, 2005
steak84ss's Avatar
LOL....yeah I was wondering about that comment earlier as well.
Ek98si
Oct 25, 2014 09:03 AM
Sinnamingrrl
Electrical DIY
Mar 13, 2014 06:56 PM
DJTazer
Jan 16, 2013 10:35 PM
jeffrey1089
Aug 25, 2011 09:24 PM
chohouston
Oct 17, 2004 09:47 PM
