98 civic Y8 IAC wires on pin outs
ok so i need to run 3 new wires from my ECU to my IAC on my 98 si civic, i have done everything to get rid of the engine code i keep getting for my IAC and get control of the bloody idle on my car, so i am going to run 3 brand new wires, because there must be a broken one in the harness. id rather run 3 new ones the chase in the damn harness.
SO the IAC wire colors are as follows many of you already know im sure
black with blue stripe (this wire is power ?)
solid orange (this wire is negative ?)
yellow with black stripe and 2 silver dots (power source ?)
Now they are on A plug for the ECU ? right ?
i found the orange & the black with blue stripe
WHICH one do i need to re-wire for the yellow with black stripe with 2 silver dots ? there are two of them side by side on the pin outs A plug on the ECU ?
all i want to do is run 3 new wires to the IAC, but i dont know which yellow one to cut and re-wire and i do not want to cut the wrong one.
Anyone can help with this ? Thanks !
yes its the 3 wire IAC motor is d16y8 automatic
Re: 98 civic Y8 IAC wires on pin outs
3 wire IAC, my info shows
Orange goes to PCM pin A13
Black/blue goes to pin A14
Yellow/black is a relayed 12v+, spliced in with the same color wires on the fuel injectors
HTH
HTH
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
KillerX
Apr 9, 2017 08:20 AM
Paul Harsze
May 20, 2015 11:37 AM
