E-Manage FAQ!!!!!!!!!
7thgen Power Maker
E-Manage Links for people that need to set theirs up:
EMANAGE: WORKING SETUPS
https://www.civicforums.com/forums/s...d.php?t=217534
https://www.civicforums.com/forums/s...=164441&page=1
Base E-Manage Maps for Turbo'd D17 with working VTEC setup
https://www.civicforums.com/forums/s...d.php?t=196730
Plug & Play harness:
Linky (Thanks 4drcivic2k1)
Wiring schematics for our car:
https://www.civicforums.com/forums/s...d.php?t=155306
VAFC wiring works the same as the E-Manage main harness, minus VTEC:
https://www.civicforums.com/forums/s...d.php?t=169767
E-manage FAQ & Install Tips
http://mohdparts.com/emanage/EmanageFAQ.txt
Outlook of wiring for all 3 harnesses
http://mohdparts.com/emanage/manuals...-manage_10.JPG
E-Manage DIY
http://mohdparts.com/emanage/install...elp/index.html
THE MYSTERY GRAY WIRE IS TPS, and is pin 15 of terminal A on our harness*
Some wiring tips for the ignition harness:
*pay particular attention to what wires go where (in terms of the INPUT and OUTPUT channels for the emanage) - you don't want to wire the OUTPUT of the emanage to the INPUT of the ECU - you may damage something
*the ignition harness has 8 wires you need to connect - 2 per channel (1 in 1 out), the injector harness has 4 wires you need to connect - 1 per channel.
*On connector A (31 pins) - which should be the very bottom connector on the ECU, pins 27, 28, 29, and 30 are for the ignition coils
*27 = cylinder 4, 28 = cylinder 3, 29 = cylinder 2, 30 = cylinder 1
*so.....channel 1 of emanage goes to cylinder 1, channel 2 to cylinder 3, channel 3 to cylinder 4, channel 4 to cylinder 2
*wire colors of the pins...pin 27 is brown, pin 28 is white/blue, pin 29 is blue/red, pin 30 is yellow/green. For the injectors you only use 4 of the 6 channels. The others you don't wire up.
Some wiring tips for the injector harness:
*wiring info for injectors is as follows: ch1 to pin 5, ch2 to pin 4, ch3 to pin 3 ch4 to pin 2
*Page 23 shows injector haress. Look at the diagram on the left - P/R = ch 4, Y/R = ch 3, O/R = ch 2, etc
http://www.mohdparts.com/emanage/man...-manage_23.JPG
*ignore channel A, B, 5, and 6.
The Support Tool update you'll need:
Update to PC Software v1.13
Firmware for unit update you'll need:
E-manage v1.39 Firmware Upgrade
Problem codes:
2gz-gte e-manage install
E-Manage DIY
Problem codes:
Alright, I took this post out of another thread in FI. There is a TON of useful info here for people who are setting up the E-Manage. Don't panic, the thread labelled "E-MANAGE: WORKING SETUP FOR EXs!!!" is listed as the first link...
Thanks to Dezod for setting this up. I have added it to the Turbo FAQ in the Forced Induction Forum. If anyone else has any helpful links, feel free to post them here.
-Havok-
-Havok-
cool. thanks. can you make a link to this in the turbo faq so it is at easy access int he fi section. mkay
-Havok-
-Havok-
7thgen Power Maker
-Havok-
-Havok-
Thanks to Havok for comin thru with the swift modness and setting it up as a sticky in this forum.
you know what would be really helpful dezod? i am not the best at wiring schematics, so if you could get a picture of the wires from the main e-manage harness and where they connect to the ECU harness, that would help greatly. ill even toss some points your way if you can get this. thanks
7thgen Power Maker
Time to get good at it.
This is how my E-Manage looks, and how it is staying.
Does anyone know what harnesses come included in the Greddy turbo kit for the RSX? I belive it came with the injector harness already in the main harness. But to clear things up. can someone just tel me which harnesses theese are? (the 2 clips that clip in the side of the harness like so?)
7thgen Power Maker
I don't know if you added it or not - but it would be a wise investment to get the pressure sensor and harness with the emanage (unless you get the profec) - you can tune off of boost vs using the throttle position. Much easier and more accurate for tuning purposes.
7thgen Power Maker
it's all filled with wires. would you happen to know which harnesses come with the greddy turbo kit for the rsx?
Once again.............the E-Manage FAQ pwnz j00 HARDCORE
The injector harness & main harness are on the same plug in harness.
7thgen Power Maker
Originally Posted by TheSmuggler
^^Holy crap when I do this I'm gonna burst into flames....
so i would only install the injc. 1-4 wires and the ground right? Oh and what is the other harness that is smaller and clips next to the main one. thats the ingnition harness right? I know im not crazy but I have a felling my wire colors are a little different. Can anyone find a manuel that comes with the greddy turbo kit. I think the wires are coded a little different. and I also have this small box with a green, white, and black wires coming from it. I'll take pics tonight. I know this is coded different.
I can barely read... I have ADHD, I can't soldier worth a crap (hands arn't steady enough) and following directions.. well lets just say I treid to build my legos w/o instructions first lol =)
It seems the greddy website Owns me. and I found the info there.But I found something out. I don;t have some of the wires you guys have. There are no vtec wires in the main harness so I guess vtec can't be adjusted which I prob wouldn't have used anyway. But I also don't have the purple VTM wire. what does that wire do?
7thgen Power Maker
7thgen Power Maker
got the main harness on but the active LED is flashing red. how do I read what code the emanage is putting out?
ok I have the support tool and my harness has no vtec wires connected or no VTM wire. But now my car starts to stall out and won't rev past 4k. any ideas?everything was ok till I updated the main unit,
oh BTW the active led is flashing from green to yellow to red over and over.
^ mine did the same exact thing. it was because it was not tuned. you also have to reset your ECU by following the instructions in the DIY Intake page.
7thgen Power Maker
the vtec doesn't seem to be working on our cars so everyone is using the 4-8-c.
what does it mean if the active led glows from green to yellow to red?
red means an error
This is if I recall correctly
VTEC remains untouched. No wires tapped or anything. Therefore, it still works......It engages. Diagnostics and dynos show it for me.
