E-Manage FAQ!!!!!!!!!
Ok I found my problem. I updated the firmware and support tool but when I try to update the main unit it will either say corresponding please wait or it will start to update and cut off after 27 sec and say update failed. Any ideas? It says that the support tool is online too.
7thgen Power Maker
Did you update the support tool?
the support tool version is saying v.1.13 (I used the update in the link in this thread)
and I downloaded the firmware but when I get to the point when I update the main unit and click on the new firmware to update thats when it just says corresponding or fails after 27 sec. and the upload only goes 1/2 way
7thgen Power Maker
got it fixed but I can't find the rpm wire. in the write up it says it's the blue wire in connector A in pin 7 but in the wire write up it says\
Connector A (31 Pins)
1-blk/wht-Primary O2 sensor heater control
2-yel/blk-Power Source
3-yel/blk-Power source
4-blk-Power ground
5-blk-Power ground
6-wht-Primary O2 sensor
7-blu-Crankshaft position<-------?
8-yel-Sensor return volt
9-red/blu-Knock sensor
10-grn/yel-Sensor ground
11-grn/wht-Sensor ground
12-blk/red-Idle air control valve
13-wht/blk-EGR Valve position VTEC ONLY
14-blk/wht-Secondary O2 sensor heater control
15-red/blk-Throttle position sensor
18-wht/grn-Vehicle speed sensor
19-grn/red-MAP Sensor
20-yel/blu-Sensor Voltage Supply
21-yel/red-Sensor Voltage Supply
23-brn/yel-Logic ground
24-brn/yel-logic ground
25-wht/red-Secondary O2 Sensor
26-grn-Top dead center sensor
27-brn-Igniton coil 4
28-wht/blu-coil 3
29-blu/red-coil 2
30-yel/grn-coil 1
4-blk-Power ground
5-blk-Power ground
28-wht/blu-coil 3
29-blu/red-coil 2
30-yel/grn-coil 1
the rpm wire is also int he engine bay if you dont wanna search for it in the connectors. it is a blue wire by the passenger side headlight
7thgen Power Maker
it says online, but it still says that even when the support tool is unplugged
i am trying to update the main unit, but it is trying to connect with it and it just keep on going, but it never does anything.
Lookin at the diagram, for the input on the ignition harness, that goes go the ECU and the output goes tot he e-manage, right?
k i got my e-manage. and i opened it to see what it was all about and i saw a boost thing you clip in. what goes into that? do i need to buy somehting else, or will whatever i have for my turbo kit clip into that? thanks
^^What kind of N/A power would you be putting out that you would need an e-manage?
One Slow Civic.... But I can take turns pretty well :-)
I don't know, I jsut saw there was a topic for maps of the n/a but no maps. I just want to have some power out of it until I get my turbo. The emange is cheaper so, I'll prob get that first.
Hmmm, I would leave the settings stock, I don't think your going to be getting ANY more power out of a stock engine
7thgen Power Maker
Originally Posted by Blahman2
I wanna get it, but I'm worried what If it doesn't work when I actually wanna use it, then its too late to return it.
7thgen Power Maker
Originally Posted by exturbo6
do these wiring diagrams work for a 04 civic?
Originally Posted by dezod
I assume it would work. Don't think Honda would have changed the ECU wiring at all. Check with your local Honda dealer to verify.
