Engine Management Post information/questions about Engine Management here! It's especially important for Forced Induction (Turbo and SuperCharging) and Engine swaps! What destroys engines are fuel management!
my EMANAGE MAPS for those interested
Old Feb 9, 2005
C2i0v0i1C's Avatar
SuperMODrizd
here
injection map and ignition map
AF map and vtec map
well they wont post, so ull just have to open them sorry
File Type: doc
File Type: doc
Old Feb 10, 2005
tfnaaf's Avatar
BLDNPSI Mod
Thanx for the post !
Old Feb 10, 2005
C2i0v0i1C's Avatar
SuperMODrizd
FYI these are STARTING POINTS, NOT PLUG AND PLAY!
i dont want any PMs saying hey it didnt work wtf!
Old Feb 10, 2005
BIG's Avatar
BIG
what kind of fuel system are you using? RSX injectors? and extra injector? return?
Old Feb 10, 2005
C2i0v0i1C's Avatar
SuperMODrizd
return with 440 RC
Old Feb 10, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
Thank You
Old Feb 10, 2005
HyaBoosta's Avatar
does your vtec engaugment actually work? if so how did you wire it up?
Old Feb 10, 2005
C2i0v0i1C's Avatar
SuperMODrizd
beats me i didnt do the wiring
Old Feb 10, 2005
abmerop18's Avatar
Jam out with your clam out.
he has the jumpers set up for vtec and the rotary at 2-8-a
Old Feb 10, 2005
HyaBoosta's Avatar
interesting. anyway to call who wired it up to see if they placed a diode on the vtm wire or the reasoning behind the settings?
Old Feb 10, 2005
TheSmuggler's Avatar
i thought 4-8-c was the settings madwheels found for vtec? lol i want my ex to work right! =*( lol
Old Feb 10, 2005
HyaBoosta's Avatar
no, madwheels vtec never worked. the write up needs to be updated so others don;t make that mistake.
Old Feb 10, 2005
Hmmm, ok, so if I really DIDN'T wanna change the angaugment point, I just don't even need to bother hooking it up rioght? I've heard way to many bad tihngs about changing it lol
Old Feb 10, 2005
That thread is titles working setup for EX's so I'm assuming he did get it to work.. but mabeh it's cuz he just stopped bothering and left it LOL
Old Feb 10, 2005
Havok2k1's Avatar
Wicked Pissah Admin
I'll add this to the e-manage FAQ when I have some time...
Old Feb 10, 2005
HyaBoosta's Avatar
I spoke to madwheel when I was installing mine and he said his vtec controller never worked and he set it up without the vtec wired up
Old Feb 10, 2005
opto_isolator's Avatar
I posted earlier (although noone ever seems to listen!) that to fix the VTEC you may just need a resistor! If you guys would listne more, maybe the folks who have VTEC could try this out....I don't have VTEC.
Old Feb 10, 2005
HyaBoosta's Avatar
^I read that post a while ago but don;t really wanna mess with my ecu too much. i'll wait it out till someone else does.
Old Feb 10, 2005
Yeah, well I'm not planning on changing my point so I'll just leave that out LOL
Old Feb 10, 2005
You're not messing with your ecu - its just a resistor - and it goes in line with the emanage wiring....It won't damage anything....
Old Feb 10, 2005
HyaBoosta's Avatar
do you know off the top of your head what size resistor it is?
Old Feb 13, 2005
abmerop18's Avatar
Here is the actual e-manage file if anyone wants it
File Type: zip
Kevin.zip (707 Bytes, 192 views)
Old Feb 14, 2005
No, sorry...If you search you'll find it.
Old Feb 22, 2005
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
Thanks for posting these e-manage maps. I appreciate it a bunch.
Soon when SF sends me a missing intercooler pipe, I will be able to install the turbo. And with these maps, perhaps I can do some e-manage street tuning. The weather has been changing much here one day it went from +15 Deg C to - 15 Deg C, does that affect the turbo car much?
Also wondering if when you get your car tuned, will the ecu adjust itself and put your settings out of tune?
Anyone use these posted maps yet?
Old Jul 14, 2005
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
tomorrow i'm gonna install my e-manage, SLP return fuel kit and rsx injectors. i'll be running around 8psi, and i'm wonderfing if anyone could offer me a base map based on this info. for the time being i believe Dezod's is the closest start for me, but i wouldn't mind comparing multiple options
Old Jul 14, 2005
BlackFire's Avatar
BlackFire is an unknown quantity at this point
But we have 3 places to plug that resistor. To wich cable that resistor should be connected?
Old Jul 15, 2005
Did Dezod post his maps?
Old Jul 16, 2005
Mex's Avatar
Mex
long ago they were posted, now they are only available on the CD included in his kit
Old Jul 20, 2005
OK, well I already have a kit, does someone have them to post again or something?
Old Jul 20, 2005
tfnaaf's Avatar
BLDNPSI Mod
I'll post my maps after tunning next friday.....
