DIY : Double Neon Angel Lights
this is way brighter then the LED angel lights I donno how long it will last but dam rite it looks good
With just Ring on
with Ring on, lowbeam on
with Ring off, lowbeam on
so here's a DIY
I used four of this Roung Cold Cathode Fan neon lights by Sunbeamtech all had diameter of 80mm and you can find it in the computer store
since computer parts and our car uses same 12v there wont be any problems with converting voltages this kit includes a fan(not needed), neon, switch(not needed) wires, and inverter
I used four of this neons
first take your bumper off and so as your headlight
take your headlight apart and you will have this part on your hand
screw off the original LED angel light
drill a small holes into red dots
cut off four edges of plastic cover to make it round
put the neon ring on, get the wiring out to the back and hold the ring with wires
now you are done with the lowbeam light now for the high beam light,
drill two holes on highbeam/daylight which will be used to hold the rings
put the neon rings without the plastic cover
put back the headlights,seal it and connect it to the inverter
do the wiring and you are ready to rock
With just Ring on
so here's a DIY
I wired it to sidelights so it will turn on when I turn the sidelights on and I also have a switch connected so I can turn em on and off while driving
hmm no one tired this so I donno how long it will last.. I will let you know if it breaks
Originally Posted by armieo
Nice... I'd rock those in red. I was thinking about doing that a long time ago but I was way way too lazy to open up my headlights again.
^^ theres some DIY of taking the head light apart in this site if you search
inverter is a thing that changes low voltage(12v) to high voltage(620v) which will light up the neons. it's included in the kit.
I spent 1425 points to do this.
the inverter came with the pc fans, prolly regulates voltage.
looks awesome, I'm just gonna wait a few months to make sure your rings last before i break into my headlights! thanks for the diy
Nice I did that with T1 11,000 MCD LEDS and wired another set over the high beams just like you did. The neon is way brighter. The only way we could get it that bright without neon is if we found some way to use fiber optics like BMW's. Looks good!
2k1civic.com O. G.
EDIT******** DIY dual angel eyes completed. pics on page 3******
Thats really good! Any updates on though? Im still wondering if the ring around the lowbeam can hold up to the heat.
Originally Posted by Hefe
looks rice.... i mean nice.....
really though... looks good!
http://www.7thgencivic.com/forums/sh...d.php?t=185591
If he gets those white ones, it will look, SOOO much better
Wish I knew korean
Originally Posted by ImPulse
50$ isnt that much just for 2 rings... I wish i knew someone that could translate the page for me
