DIY : Double Neon Angel Lights
Old Sep 22, 2004
skiboard's Avatar
this is way brighter then the LED angel lights I donno how long it will last but dam rite it looks good
With just Ring on
with Ring on, lowbeam on
with Ring off, lowbeam on
so here's a DIY
I used four of this Roung Cold Cathode Fan neon lights by Sunbeamtech all had diameter of 80mm and you can find it in the computer store
since computer parts and our car uses same 12v there wont be any problems with converting voltages this kit includes a fan(not needed), neon, switch(not needed) wires, and inverter
I used four of this neons
first take your bumper off and so as your headlight
take your headlight apart and you will have this part on your hand
screw off the original LED angel light
drill a small holes into red dots
cut off four edges of plastic cover to make it round
put the neon ring on, get the wiring out to the back and hold the ring with wires
now you are done with the lowbeam light now for the high beam light,
drill two holes on highbeam/daylight which will be used to hold the rings
put the neon rings without the plastic cover
put back the headlights,seal it and connect it to the inverter
do the wiring and you are ready to rock
ID:	38622   Click image for larger version
ID:	38623   Click image for larger version
ID:	38624   Click image for larger version
ID:	38625   Click image for larger version
ID:	38628   Click image for larger version
ID:	38629   Click image for larger version
ID:	38630   Click image for larger version
ID:	38631   Click image for larger version
ID:	38633   Click image for larger version
ID:	38634   Click image for larger version
ID:	38635   Click image for larger version
ID:	38636   Click image for larger version
ID:	38638   Click image for larger version
ID:	38639   Click image for larger version
ID:	38640   Click image for larger version
ID:	38641   Click image for larger version
ID:	38643   Click image for larger version
Old Sep 22, 2004
ImPulse's Avatar
awesome! I will Sticky this.
I wonder if the rings will melt? or "pop" ?
What are they made out of?
Old Sep 22, 2004
abmerop18's Avatar
Jam out with your clam out.
thats looks great! angel eyes almost look like a BMW. your are probally gonna have trouble with the poo-poos though =/
Old Sep 22, 2004
ImPulse's Avatar
so how do you turn them on and off?
Old Sep 22, 2004
exclusive_vtec's Avatar
nice D.I.Y
Old Sep 22, 2004
skiboard's Avatar
I wired it to sidelights so it will turn on when I turn the sidelights on and I also have a switch connected so I can turn em on and off while driving
hmm no one tired this so I donno how long it will last.. I will let you know if it breaks
Old Sep 22, 2004
armieo's Avatar
< My future wife.
I had case fans in my fog light holes for a long time and they lasted LONG... plus they were continually getting doused by rain.
Old Sep 23, 2004
isuzu5000's Avatar
isuzu5000 will become famous soon enoughisuzu5000 will become famous soon enough
what kinda bulbs did you use for the actual headlight? they look hella blue
Old Sep 23, 2004
armieo's Avatar
< My future wife.
Nice... I'd rock those in red. I was thinking about doing that a long time ago but I was way way too lazy to open up my headlights again.
Old Sep 23, 2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Ricer! haha.
Old Sep 23, 2004
IrockCivics's Avatar
very nice man.
Old Sep 23, 2004
how did you put the light apart? also whats a inverter?
Old Sep 23, 2004
skiboard's Avatar
^^ theres some DIY of taking the head light apart in this site if you search
inverter is a thing that changes low voltage(12v) to high voltage(620v) which will light up the neons. it's included in the kit.
Old Sep 23, 2004
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
the inverter came with the pc fans, prolly regulates voltage.
looks awesome, I'm just gonna wait a few months to make sure your rings last before i break into my headlights! thanks for the diy
Old Sep 23, 2004
mexinaction's Avatar
damn dat looks hot, cant wait till they have TYC's for 04's!!!
Old Sep 23, 2004
Oishi's Avatar
Oishi is an unknown quantity at this point
an inverter changes a dc voltage into (somewhat) an ac voltage...i'm not exactly sure how much a neon takes...but all i know is that it uses high voltage and very little current...same way a night light works...the main point is that in order for it to work a change in voltage is needed...hence alternating the voltage...
Old Sep 23, 2004
Civicly02's Avatar
looks nice
Old Sep 28, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
I second that ^^^
Old Sep 28, 2004
Rufus's Avatar
Nice I did that with T1 11,000 MCD LEDS and wired another set over the high beams just like you did. The neon is way brighter. The only way we could get it that bright without neon is if we found some way to use fiber optics like BMW's. Looks good!
Old Oct 7, 2004
LowRYda03ex's Avatar
LowRYda03ex is an unknown quantity at this point
i wish my halo projectors were that bright...
Old Oct 24, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
That looks really good.. too bad I don't have projectors..
Nice work
Old Nov 18, 2004
AzNmiKex215's Avatar
2k1civic.com O. G.
EDIT******** DIY dual angel eyes completed. pics on page 3******
Thats really good! Any updates on though? Im still wondering if the ring around the lowbeam can hold up to the heat.
Old Nov 25, 2004
skiboard's Avatar
It's Still Good! Cold or Hot
but it seems sometimes it needs about 1~2 seconds of worming up before it's fully bright. hope it gets throught this winter!
Old Dec 5, 2004
ImPulse's Avatar
how are they now?
Old Dec 5, 2004
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
looks rice.... i mean nice.....
really though... looks good!
Old Dec 5, 2004
ImPulse's Avatar
HE WAS BEING SNEAKY
http://www.7thgencivic.com/forums/sh...d.php?t=185591
If he gets those white ones, it will look, SOOO much better
Wish I knew korean
Old Dec 5, 2004
Hefe's Avatar
now those look good!!!
Old Dec 7, 2004
wonderz's Avatar
wonderz is on a distinguished road
why are those so expensive tho.? looks good, but for like more than $50 only 2 rings?
Old Dec 9, 2004
ImPulse's Avatar
50$ isnt that much just for 2 rings... I wish i knew someone that could translate the page for me
Old Dec 11, 2004
pon55's Avatar
E-mail the consulate in the city! Always helpfull.
