Water problem!
Old May 10, 2004
george19's Avatar
george19 is an unknown quantity at this point
Water problem!
I was wondering if you guys have had problems with water entering the cabin on the driver's side? I don't know where it is coming from! Is there any chance it could be coming from underneath the car? I ask that cuz 1 time i wasn't payin attention where i was jackin my car up and made a little hole in that stuff that covers the metal? Could that be the problem?
THanks for the help
Old May 10, 2004
Da1lyDr1ver's Avatar
as long as you lifted you car along the jack points (looks like rails) then you should be fine. the rubber stuff comes off even if you dont jack your car up. where is the water at? someone else was having a problem with water entering their drivers side floor and found out it was because his windsheild was leaking or something.
Old May 14, 2004
civicstylz4u's Avatar
civicstylz4u is an unknown quantity at this point
I clean my car out every week and I have noticed a spot near my break on the driver floor, its always wet. I think water is getting up through the floor
Old May 23, 2004
909's Avatar
909
909 will become famous soon enough
word
Old May 23, 2004
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
i posted a thread about the exact same thing but noone had the same problem as me. my driiver side back seat carpet is discolored and wet. i never left the windows open in the rain or spilled anything down there.
im gonna get my car checked out by honda soon.
Old May 24, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
When do you realize water is coming in? If this only happens during rain, then your problem is the mouldings. If this happens on a sunny day and dry roads, then the drain hole in the bottom may be plugged or the ductwork cracked or broken.
Old May 24, 2004
909's Avatar
909
"When do you realize water is coming in? If this only happens during rain, then your problem is the mouldings. If this happens on a sunny day and dry roads, then the drain hole in the bottom may be plugged or the ductwork cracked or broken."
Word_
good advice, ....
how do we check the moulding for leaks?
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
insan
Detailing
Jan 29, 2002 09:41 AM
ZSKCivic01
Detailing
Dec 27, 2001 12:46 PM
skywalker
Nov 8, 2001 05:04 PM
