Koni Shocks....
Old Apr 4, 2004
IrockCivics's Avatar
Koni Shocks....
I was told by a mechanic that the Koni shocks are adjustable so I can lower my car... Is this true? He told me how low are the springs I have, and I said 2".. he said ok so I can lower my car with the shocks 5" if I wanted. Is he right? It seems very stupid and untrue to me... Thanx guys.
Old Apr 4, 2004
h01civic's Avatar
h01civic is an unknown quantity at this point
I dont really know man but im thinking of purchasing the same koni
shocks as you so if find out just email me a n96skyline@yahoo.com, thanks for the info
Old Apr 4, 2004
flotsamm's Avatar
Konis Sports(yellows)are adjustable dampers that allow you to adjust the firmness, they dont set the ride height. However, the rears do come with a circlip that allows you to set the rear perch height at the stock setting, or about 1" higher in case you carry heavy loads or tow.
Old Apr 4, 2004
ok thank you flotsamm.... ho1civic when you get them let me know how the ride is and if they are worth buying, Thanks.
Old Apr 5, 2004
blacksheep's Avatar
blacksheep is an unknown quantity at this point
SOME koni's have height-adjustment circlip grooves that let you adjust ride height for the front and rear
On 7G civic's the front is only a strut insert : it can not modify the height of the spring perch. For that reason they don't offer height adjustment
The rear shock does have 2 circlip grooves. The lower groove is equivalent to stock height and another which is HIGHER than stock for ppl who have heavy audio gear and / or tow heavy stuff.
The ride with Konis is MUCH much better than with stock shocks, no question about it.
Old Apr 6, 2004
streetglower's Avatar
I have them and they are worth the buy. I can take corners like nothing else. Also the ride is very firm. They handle well.
Old Apr 7, 2004
FattyMcJ's Avatar
Addicted to the Twisties!
True...however...Koni's alone will NOT drop your ride-height...as much/as well as some lowering springs. If you want to drop your car go with Koni's AND lowering springs, or better yet, some full coilovers...
Old Apr 7, 2004
Does it make the car bounce? Does it matter what kind of springs? I have Sprint lowering springs.
Old Apr 7, 2004
flotsamm's Avatar
Do Konis make it bounce? No, in fact they should help get rid of the bouncing.
Old Apr 7, 2004
good. cause my car rite now bounce like hell.
Old Apr 10, 2004
Titleist71's Avatar
I just got my Konis done today....they are freakin sweet...The car handles like better than new......so quiet.....so smooth!
Old Apr 10, 2004
Decamo's Avatar
Decamo has a little shameless behaviour in the past
If its just a groove that the circlip sits in to adjust height can't you just take it to a machine shop and have multiple grooves made so you can fine tune the height exactly where you want it?
I know it would be a hassle to reassemble through trial an error but you could get the perfect stance without coilovers.
Old Apr 10, 2004
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
Got Koni for 560 Shipped to your door . LEt me know if anyone is interested.
Thanks,
Eddie
www.truehonda.com
Old Apr 15, 2004
HyaBoosta's Avatar
I got a set of koni's (fronts only) new in box. 160 +shipping.
PLUG!
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
cukaracha
Aug 29, 2015 05:27 PM
cukaracha
Jun 7, 2015 03:32 PM
