Koni Shocks....
Koni Shocks....
I was told by a mechanic that the Koni shocks are adjustable so I can lower my car... Is this true? He told me how low are the springs I have, and I said 2".. he said ok so I can lower my car with the shocks 5" if I wanted. Is he right? It seems very stupid and untrue to me... Thanx guys.
I dont really know man but im thinking of purchasing the same koni
shocks as you so if find out just email me a n96skyline@yahoo.com, thanks for the info
Konis Sports(yellows)are adjustable dampers that allow you to adjust the firmness, they dont set the ride height. However, the rears do come with a circlip that allows you to set the rear perch height at the stock setting, or about 1" higher in case you carry heavy loads or tow.
ok thank you flotsamm.... ho1civic when you get them let me know how the ride is and if they are worth buying, Thanks.
SOME koni's have height-adjustment circlip grooves that let you adjust ride height for the front and rear
On 7G civic's the front is only a strut insert : it can not modify the height of the spring perch. For that reason they don't offer height adjustment
The rear shock does have 2 circlip grooves. The lower groove is equivalent to stock height and another which is HIGHER than stock for ppl who have heavy audio gear and / or tow heavy stuff.
The ride with Konis is MUCH much better than with stock shocks, no question about it.
If its just a groove that the circlip sits in to adjust height can't you just take it to a machine shop and have multiple grooves made so you can fine tune the height exactly where you want it?
I know it would be a hassle to reassemble through trial an error but you could get the perfect stance without coilovers.
Got Koni for 560 Shipped to your door
. LEt me know if anyone is interested.
Thanks,
Eddie
www.truehonda.com
. LEt me know if anyone is interested.Thanks,
Eddie
www.truehonda.com
beanhead
Sep 24, 2015 12:04 PM
