possible FMU for our returnless?
i believe its for mustangs, but it should work on 7thgens as well. anyone using this setup?
linky
i'm still trying to figure out how to do fuel...grr.
linky
Originally posted by opto_isolator
Yeah, but its tunable - and that price doesn't include the pumps, lines, and fittings. Much easier and cheaper just to convert to return system...
i'd hate to ask, and in such a noobmanner, but i will. what does converting entail? has there been a post as to parts needed, etc. if so i missed it. thanks
What is the cost on that thing.. It looks like it would be better than SF kit. It is fully adjustable. You could tweak it with less problems on a dyno to get a good A/F ratio..
Good hunting on the web.
http://www.jegs.com/cgi-bin/ncommerc...98&prmenbr=361
If I try this out does anybody want to buy my SF FMU and fuel pump? I like the idia of being able to adjust my fuel. The VAFC2 is not that good for BOOST applications to adjust fuel. I am going to think about this.
Any input would be great.
i agree with boosted2k2. lol vortech makes a universal fmu also. im not to sure about where u r but we tryed to order that (mustang) fmu.
and our guy told us it was on back order from a while ago. and yes im excited we threw a t 60 on a 5.0 stang.
-Tap the end of the fuel rail and weld a fitting on
-attach a line from that fitting to a FPR
-atach a line from the FPR and run it to the fuel tank.
-drill a hole in the top of the fuel unit cover and install a fitting
-screw on the line
-take the intank FPR, and block it off (weld it, crimp the hell out of it, whatever. Just block it off)
Other than that... you can upgrade the injectors and pump if you need to.
CivicPunker17
Nov 30, 2002 05:09 PM
