need help with squealing belt
Old Mar 18, 2004
rino's Avatar
rino is an unknown quantity at this point
Ok I have a belt squeal that is god awful. It mostly comes from when I turn on the AC. So I check the belt on the alternator and it is making good contact with the pulley so then I look at the AC pulley. The AC pulley isn't spinning at all and the belt is just going around it, but right now it isn't squealing. I turn the AC on and the AC pulley starts spinning and then the squeal starts again. My question is, does the AC pulley turn when the AC is off because I would think it does, and if it does, is my belt just not making good contact with the AC pulley or could the compressor be seized up until I turn it on. Someone please help.
Old Mar 18, 2004
Project2k2's Avatar
1 of two things, either the belt isn's making good contact like u said, or it needs to be tensioned. I know when I lost my PS tension it squeeled like a ****ing pig raper.
Old Mar 18, 2004
cdmx's Avatar
haha so thats why mine squeels sometimes
Old Mar 18, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
lol... i had mine squeeeeeeekin for a while .. took it to my mechanic and he said that my pully's were glossed... i took a wire brush to both of them and then replaced the belt.... its quiet now..
replace the belt and clean the pully's , use some brillow
Old Mar 19, 2004
branden's Avatar
branden is an unknown quantity at this point
replace the belt or adjust the tension or you can something temporary like putting some belt dressing....you can try also armor all on the belt and pulleys
Old Mar 19, 2004
djmota's Avatar
waht you are seeing is the clutch in the ac pulley working. the pulley does not turn the ac unless you turn it on inside the car. try tightening the belt. if that doesn't work then clean the pullies and replace the belts.
Old Mar 19, 2004
cdmx's Avatar
Good idea, i wouldve never though of taking a wire brush to it though
Old Mar 19, 2004
stinkyfied's Avatar
stinkyfied is an unknown quantity at this point
Does the AC turn on / blow cold air? I had a problem where my compressor actually locked up (older american car though) and caused the belt to squeel... untill it finally broke
Old Mar 19, 2004
rino's Avatar
yeah AC works it just starts to squeal because it looks like the pully is spinning and the belt just must not be making good contact with it. I will try to pull everything off and then tighten it up really good. Oh by the way where is the tensioner for that belt around the AC pulley?
Old Mar 19, 2004
OsOBooSTeD's Avatar
OsOBaNNeD
^^^ there isnt one.. its on the alternator.. u have to losen it to tighten that belt cause its the same one
WaryDriver
Aug 16, 2015 11:22 AM
Ray Darvi
Aug 12, 2015 11:55 AM
jzhartman
22
Jul 23, 2015 10:42 PM
General 7th Gen
Jul 9, 2015 10:17 PM
1khilari
Jul 9, 2015 08:12 PM
