Oil pan "wet"?
I know this might sound like a ridicuously dumb question but I am not by any means a mechanic and was not taught this stuff...anyway, is it normal for the oil pan to be a little "wet" with oil around the drain plug? It is not dripping or leaking but it just looks like oil is all around the plug and under the pan a little. Thanks for any input!
If its a little wet, its should be ok. As long as there isnt any dripping or leaking coming from the plug. After you get it serviced or you change the oil, jack it up and wipe all the oil off and let it go for a while. Then check it every now and then.
I need TP for my bunghole
I have two instances where the dealer did the oil change and the plug was not tighten enough. Check and tighten if need be, then clean the bottom of the pan.
Back From The Banned!
If you have a garage, you can put some newspaper, or cardboard, and just place it under your car to see if there is any leaks.... or check the dip stick......
SidCivic
17
Aug 23, 2015 03:14 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
Q-Bert
Jul 19, 2015 09:09 PM
