Oil pan "wet"?
Old Feb 22, 2004
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
Question Oil pan "wet"?
I know this might sound like a ridicuously dumb question but I am not by any means a mechanic and was not taught this stuff...anyway, is it normal for the oil pan to be a little "wet" with oil around the drain plug? It is not dripping or leaking but it just looks like oil is all around the plug and under the pan a little. Thanks for any input!
Old Feb 22, 2004
civic01vtec's Avatar
it is prolly from changing the oil b4.....mine is the same way.
Old Feb 23, 2004
Project2k2's Avatar
when I change my oil, oil gets all over the bottom of my oil pan, just all over the place. Most likely what it is.
Old Feb 23, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
yea you should clean it up and see if there is a possible leak, but it is mostly from oil change.
Old Feb 25, 2004
Green Civic's Avatar
If its a little wet, its should be ok. As long as there isnt any dripping or leaking coming from the plug. After you get it serviced or you change the oil, jack it up and wipe all the oil off and let it go for a while. Then check it every now and then.
Old Feb 25, 2004
PunkingCivic's Avatar
I need TP for my bunghole
I have two instances where the dealer did the oil change and the plug was not tighten enough. Check and tighten if need be, then clean the bottom of the pan.
Old Feb 25, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
If you have a garage, you can put some newspaper, or cardboard, and just place it under your car to see if there is any leaks.... or check the dip stick......
Old Feb 25, 2004
Taffy's Avatar
THNX for the input, I have just had bad experiences with past cars and oil leaking, scares the **** outta me to think that the civic is already leaking...
SidCivic
17
Aug 23, 2015 03:14 AM
mrwhos
Aug 11, 2015 02:03 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
Q-Bert
Jul 19, 2015 09:09 PM
